Question about Kenmore 73932 Gas Dryer
Dryer want get hot
Dryer works but don't get hot.
  • 943 Answers
Here is the part you need.pull dryer away from the wall. remove back panel clean all lint clean venting from dryer to the outside. thermal fuse is located at the air duct on the left. replace this part. thanks the appliance doc. please rate my answer.thanks.
Posted on Oct 08, 2008
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
Dryer working but no heat
I'm not familiar with this particular dryer. However, I've worked on another dryer with a similar problem. That dryer had a problem with its thermostat. It failed in an open circuit condition. That means it couldn't pass current to the heater, but everything else worked. I replaced the thermostat and it fixed the problem. Here's a link to a web page where I found a thermostat for your dryer so you could see what it looks like and how much it costs. You may have to page down to get to the thermostat.
http://www.ransomspares.co.uk/parts/brands/zanussi/tumble-dryers/tc7102w%20(91609250203)/
If you want to verify the thermostat is bad before you buy a new one you could short it out and see if the dryer gets hot. If you do this, just try it out for a minute or two. Don't let the dryer run for a full cycle or it will overheat and that could be very bad.
I hope this advice helps you out.
Nov 16, 2011 | Zanussi TC7102W Electric Dryer
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
May tag gas dryer don't get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Maytag Dryers
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
Wondering if I mounted the flame cutoff sensor in the correct way. Does it mount onto the side of the burner unit? The dryer is now working but seems to be running hot.
The cutoff switch don't control the heat. Just tripps if the dryer overheats. The heat is judged by this cycling thermostatlthemobilian_2742.jpg
Mostly these don't over heat. The probo gonna be up in here:
Clean that blower housing out and party on!
Aug 04, 2011 | Whirlpool LER4634J Electric Dryer
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer takes too long to dry. GETS HOT...but not drying. Ran two cycles, frame work was hot, but clothes were not compelety dry. Note: not any lint either.??
make sure all the venting is clear of build up and debris,, clogged venting will not allow the moisture to escape the dryer resulting in damp and undry clothes ,, don't forget to check the outdorr vent and clear anything built up inside of that too
Jul 12, 2011 | Dryers
I asked for advice earlier regarding beco tumble dryer i am so sorry as i don't need advice now, i left the tumble dryer for a few hours, tried again, same result, went back to it turned it to ...
if the problem reappears,, you might need a thermodisc check,, if one is getting to hot your machine will go bonkers , Once cooled it will seem to work fine again
May 21, 2011 | Dryers
I have a Kenmore 72602 dryer, my dryer starts fine, but after about a minute the burner turs off and there is no heat, What causes this? is it an easy repair
It is an easy repair. The sensor and ignitor are ok since it will work one time when it is cooled don. The problem is with the coils. They get hot and quit. Common failure on gas dryers.themobilian_150.jpg
HOW TO REPLACE
Nov 16, 2010 | Kenmore 72602 Gas Dryer
Kenmore 73932 Gas Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
