Question about HP Office Equipment & Supplies
I have just put in a new ink cartridge and the pictures are coming out with a red tint and very dark
    Scholar:
  • 47 Answers
Hi!
Assuming this is an HP printer, "drill down" in your HP software until you find your printer toolbox (HP puts it in different spots, but you can usually find it by starting in hte printer properties dialog box in Windows control panel/printers. Inside hte toolbox, there is a tool that will calibrate your printer (which should be done every time you change cartridges). Run the calibration tool, then print a test page. You might have to repeat the process until it is correct.
Good luck, and please let me know if this helps!
Bob
Posted on Oct 08, 2008
Red and blue tint
Often "grayscale" is achieved by mixing some of your colors (CYM) to form composite black and gray - not necessarily just black from your black cartridge. Often there is some yellow used beneath the black -- so if you are getting a red or blue tint, it could mean something as simple as being low on yellow ink.
Jan 26, 2014 | Office Equipment & Supplies
Yellow ink doesn't print from the cartridge.
Try to change ink jet cartridge with a new one from hp and then blow off the contacts with compressed air. Make sure the tape is removed from the nozzles of the ink jet cartridge before installation.
Good luck on this repair.
Feb 09, 2011 | HP DeskJet 970cse InkJet Printer
When we print a coloured picture, dark colours are orangy red. Can we adjust anything to solve this problem?
If there are no issues with the head it is possible to correct the tint inthe printer. Open printer properties and select the tint settings.
make a test print after you have set and see if there is any change.
If no there can be issues with the head or the ink colours.
Sep 06, 2010 | Epson Stylus Photo R300 InkJet Printer
Photos colour is red
Use the software on the CD that came with printer, to run a "head-cleaning" cycle -- the ink is not getting from the ink-cartridges, through the ink-jets, onto the paper.
Apr 23, 2010 | Epson Stylus Photo R300 InkJet Printer
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Epson PX800FW prints coming out too red
Hi dotokpa,
There could be a number of reasons for this. The first is that your monitor may not be calibrated for print, so the image you see on your monitor is not actually how it will look when printed. http://epaperpress.com/monitorcal/ is a good website that will explain monitor calibration more in depth and will offer some free programs to calibrate your display.
It may also be that, since your printer is ink cartridge based, that you are running low in ink in some of the color cartridges so I would recommend checking that as well and replacing them if necessary.
Lastly, if you are still having problems you may need to adjust your printer settings, so when you go to print, under advanced tabs, and colour management you may be able to adjust the red, or darkness settings.
Hope this helps and please take a second to rate!
Mar 20, 2009 | Epson Office Equipment & Supplies
Light in color and won't copy dark. It come out light purple
you may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Feb 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
PROBLEMS WITH COLOR NOT PRINTING
pictures are coming out with a green tint
Aug 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
98 people viewed this question
Seeker5211
Seeker5211
