Question about HP 1250 Plain Paper Thermal Inkjet Fax
Hp 4300 My girlfriend gave me her hp 4300 all in one printer. When I fax something it has her her name and info at the top. Tried to change it and can't. Do I need the software that she used to install or is it because it is registered in her name. Can it be changed? Thank you Art
    Genius:
  • 2,120 Answers
Nope, it's buried in the menus somewhere.
Scroll through the set-up menus and look for registration, own ID or some other statement.
Posted on Oct 09, 2008
Dear Sir\madam i am user samung scx4300 printer.but 4 days ago printer problem.(Print to file.out put file name
It sounds as if the printer default has changed
Click Start - Control Panel - Printers and Faxes
RIGHT CLICK over samsung SCX-4300 and select "Set as Default Printer"
I hope this resolves your issue, if so please rate this answer below Thank You for supporting the Fix-Ya Community
Regards GM
Apr 25, 2011 | Samsung SCX-4300 Monochrome Laser...
I have officejet 4300. When it just starts to
try changing ur cartridges and then scan
Apr 15, 2010 | Office Equipment & Supplies
How do I remove the name that shows on top of a fax?
You may remove it by using the software.
The labellings you referred to is the header and footer.
You may remove them
Mar 10, 2010 | Office Equipment & Supplies
Hp 4300 officejet canot print from system command but they working fax incoming and out going and copying solve my problem
you have a problem in the computer,delete the hp 4300 from the printer menu on the computer,download from hp.com the latest drivers for your printer and Reinstall it.
Mar 09, 2010 | Office Equipment & Supplies
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Sep 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
When I click the print button, a fax window pops up, and it will only let me fax, and not print
In Windows Xp
Click on start and click on control panel
in control panel look at the top left and switch to classic view(unless your already in it,if ur in it then u'll see a lot of icons and not groups)double click the printers and faxes folder.
now look at the tow icons of your printer and one will say officejet 4300 series and one will say 4300 series fax.
right click the 4300 series and select set as default.
Now click on print if you still get the fax window select your printer icon in the drop down list and then the fax window will not popup.
IN VISTA
Click on the start button and in the start search box type "printers" and press the enter button.
In the printers window single left click the printer icon(4300 series,not 4300 series fax)
Then single right click the 4300 series icon and select set as default.
now close the window and try to print if u still get the fax popup then selet your printer icon in the drop down menu and it will print and not fax
Jun 25, 2009 | HP Officejet 4315 All-in-One Printer
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Connecting unit for sending faxes
I Googled the manual and was trying to program the unit with the fax header for date and time when I realized that this unit does not fax! The G55 only prints, scans, and copies.
My girlfriend gave me this unit specifically to address my need to send faxes in my business. I guess she assumed that being an "all-in-one" unit it did faxes too. It doesn't.
So my question is now moot but I still have the problem of not being able to send faxes.
Thanks,
Mike Hedrick
Healthy Living Technology
Sep 09, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
HP 1250 Plain Paper Thermal Inkjet Fax Logo
62 people viewed this question
Seeker5211
Seeker5211
