Question about Sharp R-353 Microwave Oven
Second oven with the same problem
The oven sparks and flashes as if there were metal in it. This is the second sharp oven with this problem
  • Sharp Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
The best place to order Sharp parts is Tritronics.
Posted on Oct 20, 2008
2 Suggested Answers
  • 306 Answers
SOURCE: Flash/sparks occrred (no metal in oven)
You know I just had a similar problem on my old unit. There was a spark and my bowl had no metal rims. I figger your ground connection has corroded at the rivets. So if you can drill a 1/8 inch hole in there and install a #8 sheet mtal screw or two to bond it togeter again.
Posted on May 04, 2009
Sharp carousel R 430 EK 1200 watts
This is not good, the magnetron is arcing because metal is exposed, this will eventually destroy the magnetron making the oven useless. I strongly suggest it get looked at for safety and potential fire hazard.
Mar 05, 2012 | Sharp Carousel R530EST Microwave Oven
Sharp r1214f sparking New issue sparks with microwave popcorn, butter and microwavable ice cream.
the container of these items probably contain some metal which doesnt go with the microwave
Jul 19, 2010 | Sharp R-1214 Microwave Oven
There is sparking from a small metallic plate mounted on the right side of our sharp R-508HS microwave, along with an ugly humming noise. this plate is adjacent to the magnetron grille. i had heated a...
Sparking in a M/wave is a problem as it can damage the works. Not sure what the plate is you speak of, Generally all metal objects are painted with enamel to prevent sparks. The humming is a worry though as it indicates something not functioning correctly in the Magnatron which is a large transformer like object. M/waves are not as expensive as they once were and can be picked up second hand under warranty from cash exchange places for about $30 onwards. I recognise that even that is an expense you dont want, but to continue to try and use a sparking MW is dangerous and is often not worth the money you spend on repair, against a used or refurbished one with a warranty.
Sorry I cant come and take a look for you ( I am in Australia) and help you out any further. But my advice is if you cant fix it yourself easily, Ditch it and replace it with a used one.
Sep 24, 2009 | Sharp R-508HS Microwave Oven
May 04, 2009 | Microwave Ovens
Flashing or arcing when power is turned on
Quite often this is due to grease or food particles stuck somewhere in the cavity / floor of the oven or stuck on or behind the waveguide cover.
Nov 22, 2008 | Frigidaire GLMV169D Microwave Oven
Microwave started sparking and making noises a few seconds after its turned on. The sparks are behind a white colored rectangle in the right wall of the oven. Can anyone please help.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
Aug 06, 2008 | Sharp Microwave Ovens
Sparks coming in side the micro oven. when I start the micro oven sparks are coming in side the oven.
Aug 04, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave sparking, etc.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 21, 2008 | Sharp R-520LK Microwave Oven
My sharp r-510hw flashing like crazy
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Mar 22, 2008 | Sharp R-510HW Microwave Oven
Dacor Microwave
The part would be much cheaper if you get the Sharp version (these ovens are made by Sharp) instead of the Dacor branded part.
The model DMT2420 is essentially the same as model R440D / R540D.
The Sharp part number is PCOVPB085MRP0 (zero on the end) and you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Mar 17, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Sharp R-353 Microwave Oven Logo
67 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
