Question about Kodak EASYSHARE 5100 All-In-One Printer
Printhead how to put printhead in printer
  • 1 more comment
  • starlight1 Oct 10, 2008
    how do i replace printhead on easyshare5100 all-in-one printer
  • Anonymous Oct 13, 2008
    same here how do you do that
  • Anonymous Nov 07, 2008
    HOW DO I GET IT OUT????
If you look at the existing printhead, you have a sticker with somekind of a target pattern, just look above in the molded plastic there is a small tab, just press on it , it will release the printhead..
i really had to look toroughly myself, and i ve been a service tech for 18years.
have fun
Posted on Oct 13, 2008
Officejet K5400 Won't print yellow
Hi David,
Turn Off Your Printer Remove K&Y Printhead from your printer. Put the Printhead in the bowl in the same Position As in the Printer And Pour Little hot water in the bowl till the printhead is half dipped in the Water. Leave in for 15-20 Min. after that Clean the Printhead with clean clothes.. Must Ensure that no Water is in the Circuit of Printhead. leave the printhead for 30 min. After that put Back in the Printer. You will Get the Better result than ever BUT PLease Donnot use clean Printhead Utility immediately after this process use after the Day. If it Doesnot Work Then Clean the Printhead in Hot Water Several Times.. Do not Remove Printheads Regularly From Your Printer..
I Have the Same Printer And Suffered Same Problem A Month Ago with Yellow Colour...
Regards,
Sean
Aug 10, 2012 | HP Officejet Pro K5400 All-In-One InkJet...
Tip
Printhead won't Print color ink black yellow purple blue red cyan magenta
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead.
or if you dont want to wait on the phone....
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipes many times and it works like new. Here is a link to the product.
http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove the printhead from the printer. put the tanks back into the printhead. Be very carefull not to drop the printhead and do not put the printhead on a table with the nozzle plate down (where the ink comes out). take the hand wipe fold it a couple times. Gently wipe the printhead nozzel plate in the direction of the lines on the nozzle plate do not do a circular motion or wipe against the grain. you may not even have to use a wiping motion. you can just place the wipe on the nozzles and let the printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
I hope this helps.
SDtester.
on Oct 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Why does the printer ask for calibration every time I turn on the printer?
It seems, Printhead has come loose or has gone corrupt.
Try reseating the printhead, do calibration. It should help you out.
1. Take both ink cartridges out.
2.Take printhead out
3. Wait for 10 seconds.
4. Put the Printhead back in.
5. Wait for 5 seconds.
6. Put the cartridges back in.
7. Go to Maintenance (Printer Conrol Panel or ? Help on your Home /Center software) and clean printhead.
NOTE: If issue still persists, pls contact kodak for printhead replacement.
Best Of Luck
Nov 17, 2009 | Kodak ESP 5 Printer
How to install new printhead
first You need to open the printer access door of your printer for you to able see the ink cartridges and the printhead. Now if the printhead already on the center remove first the ink cartridges. Now without the ink on the printhead you should see a white sticker or bulleye sticker on the middle of the printhead, Now On that sticker put your index finger upside down then move your index finger upward until you feel a latch or a tab that you can press, just press and pull, i guarantee you it wil removed.
Now if the printhead is removed put your printhead on the carriage then put the printhead all the way in until you hear a click sounds.
Note: Just take a time the latch or a tab on the printhead is hidden it will take a time for you to remove it especialy if this your first time to do it. That's base On my experince
Nov 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Change print head on kodak 5300 printer
Are your asking how to replace the printhead?
First you need to turn On the printer and open the printer access door where you can see the Ink. Now wait for the Printhead to stop into the middle then remove the ink cartridges both ink and black., Now to rmove the Old printhead you need to press a Tab which is hidden on the printhead., heres the step to remove the printhead which for me the hardest part
-Point your index finger on the white sticker that attached on the printhead or the bullseye sticker(If theres no white sticker on the print head just put your index finger on the middle of the printhead)
-Now your index finger is on the middle of the white sticker right? Move your index finger upward unti you feel a latch that you can press., Just press and full then your printhead wil be removed
-Now Your ready to insert your new printhead
-To insert new printhead just put the printhead on the carriage of the printer and gently press the white sticker of your new printhead make sure that you will hear a clicking sounds then put your cartridges back
-Theres some instances that the printhead will not stay on the middle., it keeps on staying on the right or on the leftside for you to solve that heres the step
-Turn on the printer open printer access door and wait for the printhead move into the center and if the printhead its on the center immediately unplug the power cable so the printhead will not move.
GudlucK
Nov 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to install a new printhead in 5500
GudlucK
Nov 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
HP K5400: Y and B color are failing printing
Apr 29, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
My printer wont print black inc and when i want to print color it only prints pink no matter what color i want to print. it is a Kodak easyshare 5100. I just went and bought new inc of the printer to. Any...
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead and free inktanks.
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipe many times and it works like new. Here is a link to the product.
I hope this helps.
I used my printer to do a photo guest book at my sisters wedding it turned out great (i wipped the printhead before i started all the pictures look perfect!)
SDtester.
Oct 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Easyshare 5100 All-In-One Printer
I hope this helps.
SDtester.
Sep 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Hp deskjet 20ps printhead problem
Try this.,
let me tell you that the issue will be with the printer hardware but you can try this:
Take a cloth and put little bit of water.
Clean copper contact of the printhead slot and on the printhead...now try to put the printhead but make sure that the conacts has dried up.
>>Do a pwr drain(take out the powr cord and press and hold the power button for 20 sec and release it and plug in the cord back.
>>>>To get detail info of the printer.....log on to HP.com >>support and driver >>select the support radio button.>>put the product name and the os and then you will find manuals and user guide will as information with the pictures.
Let me Know.
Best wishes,
Suvrajit
Dec 12, 2007 | HP Business Inkjet 2200 Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
419 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
