Question about Samsung SyncMaster 551 15" CRT Monitor
15" CRT Monitor samsung totally dead
I have a Samsung 15" colour Monitor which is not switching on ,there is some sound when the power is applied.How i can repair this monitor ?
  • Anonymous May 19, 2009
    but its not working
  • 65 Answers
Dear munu007 good morning this is viswanath
Don't worry I can salove UR problem
1.First U can check any physical damage in power supply (220/400v)Main capacitor,
2.And also check LOT It's OK Than Remove H O/p Transister, check SMPS output voltages ,voltages are currect That means SMPS is OK.Check Boosting FET IRF630(Q402)Change it New One,and also change the IC604 7805 Regulator.
Finally change LOT.
check any dry points (SMPS&Hori.)
Posted on Oct 10, 2008
I have colour issue with my Samsung CRT 55V monitor. The main colour look green and also the Red and blue works It seems to be an issue with the RGB cables soldered to the wrong pins. Please guide..
I think this problem might be VGA cable or colour IC of the monitor,so please if you can change these two things ,so very well, other wise you will go to the service center.
JAIN_IT {INDIA}
Sep 26, 2010 | SAMTRON 55V 15" CRT Monitor
My SAMSUNG SyncMaster753S CRT monitor has got a starting problem. It does not get on some times .No loose contact.It switches on only after the server got on.There no other problems.Display is perfectly...
With the new flat panels all the rage, you can buy a new and maybe better monitor for next to nothing. Or, as I heard about and then found one, people are leaving perfectly good, functional monitors out on the street for trash pick-up all the time (I assume they have a new flat panel and can't sell a CRT for enough to even bother listing it. I wasn't looking, I was walking my dog, and came across an amazing functional Compac crt monitor! Look around? Repairs are not worth the price
Jun 15, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung 15 inch CRT color monitor it display everything in too green color while On...
Could be a pin is damaged in the 15 pin connector or the cable is damaged. Have you tried adjusting the colour controls?
Oct 17, 2009 | Samsung SyncMaster 551 15" CRT Monitor
I have a Samsung CRT monitor, every time when I switch it on it constantly changes the colors for atleast 20 min... after that it just works fine. is there any options to service or changing the monitor...
Sounds like the monitor have a "cold joint" or having issues with overheating parts. I believe your monitor was used for long periods of time with no power saving active.
If you are a technician and are planning to fix it, you need to solder all cold joints. Also maybe the filaments inside the CRT are reaching the end of it's life.
Instructions how to open the samsung display: http://josepino.com/?open-samsung-back-cover
Dec 22, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor No display
1. Power is comming or not.
2.Check Horizontal Transistor.
3. Disply cable. 1,2,3, pins & 13, 14 pins continuty.
4. Filament supply , drypoints in neck board.
5. filament supply diode, capacitor.
Oct 23, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15 in.CRT
If the power cable is detachable, you can check it for continuity with a multimeter.
If you are aware of the hazards of imploding glass, high voltage, and x-rays, you might consider opening the monitor to replace a fuse.
May 23, 2008 | SAMTRON 55V 15" CRT Monitor
No power
do you tackle the hot. I am sure it must must be ok by now.
Nov 24, 2007 | Samsung SyncMaster 753S 17" CRT Monitor
Open cover of Samsung Samtron monitor
remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
Oct 30, 2007 | SAMTRON 55V 15" CRT Monitor
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Samsung SyncMaster 551 15" CRT Monitor Logo
230 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
