Question about Insignia IS-LCDTV32 32 in. Television
Strange pink overlay/or failure with display
Bought a 32-inch; Insignia tv, plasma, 720p,in Aug.2008. Recently, the screen has an uneven dark pink wash on it--as if someone had lightly wiped part of the screen with pink chalk. Today, the display did not come up when I turned the set on, but showed a dark mix of random colors. The sound was fine. I turned it off, then back on, and it came up but with the pink wash. Have had the same thing happen several times now: first turn on, no display or dark colors, then 2d time fine except for pink. Is the set defective or what? What should be next step? It's only 2 months old and was not a demo, but new in the box. We're on high def DirectTV.
  • wtayl Oct 15, 2008
    Okay. Solved my own problem, so maybe this will help someone else. Finally, got a 'geek squad' member from Best Buy to the phone--took four efforts. He suggested that I unplug the HDMI cable and put it back in its slot to reset OR move it to another one of the HDMI slot. I moved it from HDMI-1 and plugged it in HDMI-3, which is on the side. The pink overlay disappeared.
    Incidentally, he suggested that if I had the same problem with every port it was "probably the cable box." Don't know. Just know that moving HDMI cable to different port solved the problem.
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: I've had my 32 inch
Your set was made by LG and probably was assembled in China. Unfortunately, LG's track record isn't very good from what I have seen just from this site and have seen negative comments elsewhere. If you purchased it new, I would be looking for the nearest 'authorized' service center.
Posted on Jan 28, 2009
SOURCE: Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
Posted on Aug 28, 2009
SOURCE: Insignia NS-LCD32 - 32" 720p Flat-Panel LCD Turns itself off, resets, then turns back on
It's haunted. You must appease the spirits with a virgin sacrifice.
Posted on Jan 15, 2010
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
My 32 " Insignia- 32"
The easiest way just call up the Insignia Corporation trade it in for some money value for the next new tv u buy from them.Or take the tv aparts,pieces by pieces to sell it on Ebay.com for as salvages tv PCB boards for another tvs that the people looking for refubishes PCB boards parts to repair their tvs.
Jan 15, 2011 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Cracked plasma screen
honestly probably not worth it
May 31, 2009 | Insignia 42" Flat-Panel Plasma HDTV
I've had my 32 inch Insignia plasma tv for a month now and the screen started showing pink and yellow colors, while i am watching tv. Why is it doing that?? Is this brand/model a defective one??
Jan 28, 2009 | Insignia IS-LCDTV32 32 in. Television
32 inch insignia plasma tv
Check all the cable connections while the TV is on, both at the TV, and what the cable is connected to.
I suspect the problem is in the TV, and you'll have to wait for the Geek Squad.
I doubt leaving the TV on caused this, and good thing it happened when it did.
Jan 27, 2009 | Insignia 37" LCD Flat-Panel HDTV
Convert 480i to 720p
Turn off cable box.
Turn on TV.
Hold down media and guide for a few seconds.
On TV pick the resolution you want. Your choices are 480i, 480p, 720p, some wide screen resolutions and 1080i.
Save the results.
You should be good to go.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
Dec 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
