My Norcent 4240HD tv just shuts off for no apparent reason. I unplug it then turn it on again.. then it does the same thing. The green LED "on" indicator remains lit. The remote control will not have any effect. Where can I get this fixed
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and re-plug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. Try the slap test – Hit the TV firmly on the side. If there is any change in the picture, it could indicate a possible solder problem / connections. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first. If are unsure how to do this, try to get a friend who knows this kinda stuff to do it for you, or get a qualified technician.
Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
If none of the suggestions work, then I recommend calling in a professional to get the set fixed.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 08, 2008
Norcent Technologies PM-4201 42 in. EDTV-Ready Plasma Television that turns itself off within one second. Then the remotes don't work and I have to unplug the tv. Is the tv shot?
That might be a factory fault don't hesitate but to take it to the retailer if still under guarantee. Or phone the manufacture for a quick respond.
May 03, 2017 | Norcent Technologies PM-4201 42 in....
TV TURNS ON BY ITSELF?
Presuming it does not come on by itself at the same time each day it has to do with something affecting the microprocessor in the set-- how often and what is the pattern of it doing this?
Jun 13, 2012 | Norcent Technologies PT-4240HD 42 in....
I need to find a table stand for this TV. Thanks Garymj@cox.net
I purchased this table stand for my television from Best Buy:
http://www.bestbuy.com/site/Deco+-+TV+Stand+for+TVs+Up+to+42%22/9346264.p?id=1218088668294&skuId=9346264
It is 42in and setup was really easy. It was a great buy after many days of research.
Mar 01, 2011 | Norcent Technologies PT-4240HD 42 in....
My plasma tv powers down
hello, Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement. Hope this will help
Jun 02, 2010 | Norcent Technologies PT-4240HD 42 in....
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
