Question about Jenn-Air Refrigerators
I plugged in my jenn air bottom freezer refridgerator and the freezer is getting cold but no the fridge
  • 943 Answers
Hi thanks for the question. it takes at least 24 hrs for a fridge to get cold. so depends how long its been on. if on for more than 24 hrs. check the fan motor in the freezer . thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 08, 2008
Why won't my refridgerator or freezer get cold? I replaced timer/defrost.and defrost heater.
You need to replace the compressor relay. Power off the fridge untill you replace it otherwise compressor will be burnt out
Sep 06, 2014 | Jenn-Air Refrigerators
My jenn air refridgerator once a day leaks out a puddle of water
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 22, 2011 | Refrigerators
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Refridgerator is warm freezer is cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 29, 2010 | Jenn-Air JFC2089HE French Door...
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Condensation in refrigerator even in the morning
Are the temps in the fridge and freerzer as cold as they should be? The air circulates through the unit and the moisture is taken out in the freezer by the evaporator coils. If they are not cold enough the moisture won't be taken out. The freezer fan has to run to do this and the damper (vent) between the freezer and fridge has to be open. A door not closing good and leaky door gaskets will cause excess moisture.
Aug 19, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
No cold air n at all in refridgerator or freezer oadmirall sideo
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Sep 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
101 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
