Question about Canon CanoScan D646U Flatbed Scanner
Canon CanoScan D646U Scanner drivers for Windows 7 (32 bit)
    Top Expert:
  • Canon Master
  • 29,834 Answers
They will be available on canon's web site. If not, it is not a compatible OS.
Canon global
Posted on Mar 31, 2018
SOURCE:
  • 18 Answers
SOURCE: driver download
Dear Sami Kotaich,
unfortunately your Cannon has not released drivers for vista for this product.
I can give you one suggestion; connect your scanner with vista PC and atleast let it try to install necessary USB drivers. once it has been done you will see message your hardware installed or there was a problem installing drivers for your hardware and it may not work properly.
now leave scanner connected and go in start menu- programs- accessories- paint
once you are in paint click on File Menu then From Scanners or Cameras. if it does recognize and you get scan wizard then you will be able to use your scanner on vista. but if it doesn't recognize then I am sorry you might need to get more authentic recommendation from Cannon support.
let me know does it work or not? or if any more questions, please do not hesitate to contact me.
Many Thanks.
AJoshi
Posted on Mar 18, 2009
SOURCE: Canoscan 4200f Problem with Vista 32 bit
http://www.usa.canon.com/consumer/controller?act=OSCompatibilityArchiveAct&fcategoryid=2122&keycode=vistadr
Posted on Jun 16, 2008
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Posted on Jun 24, 2008
technical114
  • 1851 Answers
SOURCE: I've an old Canon Canoscan
There are no available drivers for windows 7 operating system for your scanner. You can download the official windows xp drivers from this link and before run the downloaded file right click on the file and at the compatibility section check the windows xp sp3 compatibility option and hit apply - ok. After this run the file as usual. This procedure will install the drivers is windows xp sp3 compatibility mode.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 02, 2011
  • 5909 Answers
SOURCE: Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
Unfortunately, Canon is not supporting Win7 for your scanner. There is a Vista driver (and one for XP). If you have Windows 7 Pro or Ultimate, you can run your scanner in the XP mode (that creates virtual PC). To access the scanned documents, you may need to transfer them to an external medium to share between the "two" computers.
I hope this helps.
Posted on Jan 01, 2010
Testimonial: "Thanks for a very fast answer. I have Win 7 Prof version so i tray to follow your rec."
I am running windows 7 and did everything possible to install my Canoscan D646U scanner but it keeps on telling my there is no drivers. Please help. Charmaine
Hello Charmaine,
Sorry to tell you but your scanner is not compatible with Windows 7. It only supports Windows 98, 2000, ME and Windows XP.
http://usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_d646u#DriversAndSoftware
Sep 07, 2011 | Canon CanoScan D646U Flatbed Scanner
I have windows 7 and am looking for a driver for my scanner. It is a CanoScan D646U. what is the easiest way to get the driver for my scanner?
Ther is NO driver above windows XP on the Canon website for this device. You can try for yourself by clicking the link below, but I suspect you will need a newer scanner. Sorry, Ian.
http://software.canon-europe.com/products/0000447.asp
Aug 08, 2010 | Canon CanoScan D646U Flatbed Scanner
Vista not supporting CanoScan D646U ex
You maybe able to download the Vista driver from the Canon WEB site from their support/download page.
Sep 30, 2009 | Canon CanoScan D646U Flatbed Scanner
CANOSCAN D646U NOT HAVE DRIVER FOR WIDNOWS VISTA
Try to run windows vista in compatibility mode. If you can't find the driver for it, even under driverguide.com, this is about the only other thing you can try.
Aug 09, 2009 | Canon CanoScan D646U Flatbed Scanner
CanoScan D646U driver for Windows Vista
you have to install vista driver then only it will work plz check the canon website
Oct 14, 2008 | Canon CanoScan D646U Flatbed Scanner
Canon CanoScan D646U Flatbed Scanner Logo
3,544 people viewed this question
Clive
Clive
old marine
old marine
