Question about HP Office Equipment & Supplies
How to change a fuser on a HP LaserJet P3005 - HP Office Equipment & Supplies
  • HP Master
  • 4,338 Answers
You can download the complete manual here, It is in 2 parts. I have downloaded the manual to my computer. The Fuser replacemant starts on page 101 of the first part of the manual. You may have to copy and paste the link into your browser. Also when you click on part 1 or part 2, select "free user" it will go through a 30 sec clock the give you the option to download. It works.
http://printer1.blogspot.com/2008/04/hp-laserjet-p3005-printer-service-and.html
If you have problems I can email you the 3 pages you need.
Joe
Please remember to rate Techs who assist you for free :)
Posted on Oct 09, 2008
  • 13 Answers
SOURCE: how do i change the fuser?
CAUTION: Fuser may be hot. Turn off printer, unplug it and allow it to sit for 20
to 30 minutes before performing these maintenance procedures.
Fusing Assembly Removal and Replacement
1. Remove Back cover:
a.) Open the face up delivery door and press the door down to disengage two door stops
b.) Remove the two screws just above the door stops
c.) Swing the bottom of the cover out first, and then the top
2. Remove I/O cover:
a.) Rotate cover to clear the tabs on right side of cover
3. Remove fusing assembly:
a.) Disconnect black cable above main power cord receptacle
b.) Disconnect two cables on left side of fuser
c.) Remove duplex inlet guide (below fuser) by lifting two locking tabs
d.) Remove four screws from each corner of fuser
e.) Pull fuser straight back
4. Reassemble in reverse order
I have done 15 service calls on these printers
Posted on Jul 27, 2009
jeffdynamics
  • 18 Answers
SOURCE: HP LaserJet 3030 Fuser Rollers
fuser roller is part of fuser assimble so you need to do is removed first fuser assy set aside and replaced the roller..tnx
Posted on Apr 14, 2008
  • 81 Answers
SOURCE: how to replace fuser drive assembly on HP laserjet
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer. It may help you with replacing the part
Posted on Jan 01, 2010
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
seeker5211
  • 1089 Answers
SOURCE: i have problem with hp laserjet p3005 with paper
If you are getting jams in the fuser, then there may be paper stuck in there, or the roller sleeve is damaged or the drive gear could be bad. You are going to have to take the rear cover off to look at the fuser.
Someone trained is going to have to remove the fuser to inspect it.
Posted on Jul 13, 2011
I have problem with hp laserjet p3005 with paper jams inside fuser assembly, i already clean the rubber roller then still the same problem occure...please someone help me.....sorry for my bad english
Jul 13, 2011 | HP LaserJet P3005 Printer
I need the way whitch i can take in order to replace the fuser of the Laserjet Priner P3005n
Remove back door, you can see the fuser assm, remove four scarews, three connector, lect power & right side two connectors remove them take fuser out
Mar 22, 2011 | HP LaserJet P3005 Printer
Paper is wrinkled on one side
Hewlett Packard P3005 Fuser
The HP P3005 fuser is located at the back of the printer.
The fuser has a thin film upper roller which can be torn, some symptons can be "Wrinkled Pages","Poor Fusing", "Toner Rubs Off the Page", "Pieces of black Plastic Come Out".
*** The printer should be unplugged from any power source before any servicing is performed ***
The rear cover can be taken off by removing 2 screws. Once the cover has been removed the fuser can be removed by taking out 4 screws and 3 electrical connections.
Part Number and purchasing link below
RM1-3717-020
Jan 16, 2011 | HP LaserJet P3005 Printer
My HP Laserjet P3005 is almost 2 years old and needs a new fuser assembly. Is this normal? How much should this cost? Would I be better off buying a new printer
The fuser is suppose to last up to 200,000 pages, however they rarely get that far.
RM1-3717-020
Dec 07, 2010 | HP LaserJet P3005 Printer
Verticle lines printing on laser printer
Check the fuser. If it is the fuser, you should be seeing 3 dark lines on the fuser film. Here is the picture about how the film looks like:
Changing the film usually solve the problem. However changing the film itself is difficult. You have to remove and basically disasseble the fuser, and change the film. However it is fairly cheap and if you decide you would like to save some money, here is the link available in ebay:
http://cgi.ebay.com/Fuser-Film-Sleeve-HP-LaserJet-P3005-RM1-3740-/250558576965?cmd=ViewItem&pt=BI_Toner&hash=item3a56747945
Or, simply search for 'P3005 Fuser Film' and you will find a lot.
Other than that, you can change the entire fuser. Please note that fuser for P3005 is not consumer installable part. You still have to take out some parts in order to change the fuser.
The parts are available from many parts supplier. Simply google 'P3005 fuser'. Usually around $100 for a refurbished fuser.
You can also recycle your old fuser and get some moeny! (about $15-$25 per fuser).
Apr 09, 2010 | HP LaserJet P3005n Printer
We have put a new toner in but still we are experiencing lots of horizontal lines??
Nov 17, 2009 | HP LaserJet P3005n Printer
747 people viewed this question
Ben Johnson
