My monitor is....
I have been using this monitor for 2yrs...is working alright but it has become dark.at first i thought it was the settings on the monitor but rather found that the brightness settings on the monitor is 100%. so meaning is not the monitor setting.when am watching movies i have to use the windows media player settings to make it clear.i need help.
  • 65 Answers
Increase Screen Preset of LOT (Bottom Preset)
Posted on Oct 10, 2008
Monitor getting dark
Your top backlight element is not working, probably burned out or has a wire that has become disconnected or burned off at the end of the bulb. You will need to replace the top bulb and or reconnect the soldered wire.
Apr 01, 2013 | HP w2207 Monitor
Very dark screen in full screen mode
Check the monitors native resolution (you can get it in their website's technical specification area and set the same resolution in your windows resolution.
Jul 22, 2012 | Dell Dimension 8400 PC Desktop
I have an LG Flatron L1530S monitor. It had been working perfectly fine. However, since a month, when I used to switch it on, the screen would come on, and then become very dim, though the display would be...
More likely to have dying power supply due to bad DC filter caps as you can see in my albums here:
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Failed LG: http://s807.photobucket.com/albums/yy352/budm/LG/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Aug 02, 2011 | LG Flatron L1512S 15" LCD Monitor
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
Picture becomes all dark and obscured at times
HI,
PICTURE BECOMES ALL DARK AND OBSCURED TIME WHILE WINDOWS,ITS A PROBLEM OF GUI (GRAPHICAL USER INTERFACE).TAKE BACKUP OF C PARTITIION BY KEEPING EXTERNEL CASING AND JUST FORMAT A SINGLE C PARTITION THROUGH WINDOWS XP CD.
BY
ALLIED
Nov 04, 2009 | Relisys Intro TE555 15" CRT Monitor
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
SyncMaster 940B
Sounds like you have a video card problem. If it works on someone elses PC and not yours. Replacing this video card on your PC should fix it..
May 14, 2009 | Samsung SyncMaster 940B 19" LCD Monitor
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Blurry and dark picture
Is the issue occuring only with the webcam, or is the picture quality of the new monitor bad in general? I would suggest checking the monitor properties via control panel. You can also try reinstalling the webcam drivers. Try that first and let me know how it goes..
Oct 26, 2008 | Logitech QuickCam Fusion Webcam
Dell P793
Check condesators that connect to G2, normally they are two 1nF 2kV. Replace them and will work
Apr 10, 2007 | Dell P793 17" CRT Monitor
Computers & Internet Logo
397 people viewed this question
David Payne
David Payne
