Hi.......i have accumalated a few problems on my 6533 acer laptop..i need help...i will list a couple of the problems ......1.when i try to activate my cam it said being used by another application and there is no other application using it, i have tried reistalling software for the cam but to no avail..now when i click the logo to start the cam nothing happens..my cam is built in called orbicam 1.3 mp...the other annoying problem is power saving option.......i cant seem to access the power options in my control panel ...when i click it again like the orbicam......nothing happens.....i hope someone can help....MANY THANKS ..karl
this seems like a no boot / no video kind off issue and mostly is coz of corruptions in softwares or drivers, try booting the computer in safe mode. if it does, then take a data backup. i would not recommend experimenting in this issue as it can crash the computer.
hence call 1-877-805-1027 for expert help.
Hi There, Ultimately I can help you much better with a model name/number of your laptop. However, here's a few things you can try - 1 - check to make sure it's not connected to any other video sources (all VGA/Docking Stations/HDMI/etc cables unplugged from the laptop) 2 - Remove the battery and power plug, and hold down the power button fro 60 seconds. Then reinsert the battery and plug and turn it on. 3 - Some laptops are prone to overheating, causing the video chips to degrade over time. This was a big problem with many HP, compaq, Asus, Acer, and Dell laptops. Check wikipedia for a list of prone laptops.If yours is on the list, it's toast.
Try to hard reset the laptop first if that will help. Most of Acer laptop had the following hard reset:
1. Remove the battery and the power adaptor.
2. Press ESC or F2 key for about 2 minutes.
3. Then while continue pressing ESC or F2 key, plug the power adaptor and turn on to the power button.
4. If you able to see the bios or ACER logo then, you will be able to check the problem if it is on the harddisk, memory or your OS.
PM me if any help.
Press the Bluetooth button on the Laptop and it should enable the bluetooth function.
If that does not help, try the steps below.
Click on Start Button, Control Panel, System. Next check to see if your have a
"Bluetooth device in your list (should be at the top under Bluetooth
Radio's)
If you computer has the device installed it will tell you. If
you right click on the device and go in under properties it will tell
you if the device is working properly. You may need to just update the
driver
Basic steps to check bluetooth connectivity or activity is.
1. first enable/start bluetooth on ur Laptop & Mobile !
2. then search for devices in the menu..
3. it will show u a list or a name of ur single device..dat may be ur laptop/mobile name !
4. select dat device and it will make the connection
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
We ran a typical Acer aspire one battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
This model comes only with 1 speaker which is located on the left side.
You can see it if you look from top down above the speakers with good lighting.
Although they list it as setero in the spec, it is actually not.
If your laptop's "fn" key is active, you can't use the normal keyboard keys, they typing schemes are not different, well, your "fn" key might be active, so to deactivate it, press the "fn" key and "numlk" numlock key simultaneously and hold on for few seconds and release. This will fix your problem. good luck
1. try changing the SATA mode to IDE for the restore and then back to AHCI mode after it was complete
2. Enable disk to disk recovery mode: To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this
value to Enabled.
