Question about Minolta magicolor 2350 Laser Printer
Fuser jam The paper is crimping up into an accordian at the fuser.
  • 2 more comments
  • SJoval Oct 10, 2008
    This happens repeatedly. I've done the above solution 10 times. I need to know why it happens and how to fix that or I need a new printer.
  • delo2009 Jan 02, 2009
    At first it was only the first page that came out folded accordion style...  The last few weeks, the first page has been jamming in the fuser (orange rollers near the top of the printer).  After freeing the first page, I can get it to print but now it appears all of the pages are coming out folded.
       There are 10 to 12  horizontal folds along the entire page.  It's as if the paper is being fed from a faster roller into a slower roller where the paper becomes slack and folds and then goes through a fast roller again to stretch the paper out.  The image is clean looking so I don't suspect the problem is happening before the image drum.
  • Anonymous Mar 10, 2009
    I have the same problem but the print quality is now getting worse. It is no longer just the first page.
    Printing Black and White only seemed to work but that now fails.
    I want to fix this as its only printed 6000 sheet and has full toner cartidges. Its also a great printer when it works
  • Giulio Moro Feb 04, 2013
    It sounds like something is jamming or obstructing the paper path, or a roller is sticking or became damaged. Check the entire paper path and manually roll the fuser to make sure it's not damaged as well.
Switch OFF and let it cool for 10 minutes. If the paper is concertina'd into the top of the fuser unit, raise the two green levers and pull the black flap forwards. Use the mis-feed clearing knob (turn anti-clockwise), and carefully remove what you can from the top. This may leave some of the paper tucked inside behind the back roller.
Make sure your hands are clean. Keep the black flap open towards you, and lower the green levers so that the rollers re-engage. Press with your finger to trap any paper ends firmly against the back roller, then turn the misfeed-clearing knob anti-clockwise. This pulls the paper back out of the gap.
Posted on Apr 25, 2013
Drop the cover down and release the 2 green cilps and allow the paper to be pulled out
Posted on Oct 10, 2008
Dell 1320c printer jam
Your paper is probably stuck in the fuser. Open the front, top of printer. There are two blue tabs on either side. You have to remove the fuser and gently pry the paper with your fingers. It's probably crunched up like an accordian. Don't use any implements and don't touch the fuser. GENTLY is the key here.
This probably happened because the paper was too thick or you were printer a full page of ink and the paper got sticky.
Jul 19, 2016 | Dell 1320c Laser Printer
Paper jam before printing process
more than likely your fuser is not turning the gear may be bad on the fuser or an internal gear.
Jun 30, 2014 | Sharp Mx-4111n Multifunction Copier
Paper jam internal, can't access. accordian at exit tray
more the likely it is in the fuser unit of the copier .
May 04, 2010 | Canon ImageClass D880 Copier
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
Jamming
Hello sir; Go make a copy let paper jam again, do not remove the paper, check the jamming paper area see there have any paper chip stuck in the paper path, clear it, otherwise cleanup roller with alcohal.
Jul 20, 2009 | Ricoh Aficio MP1600SPF Copier
Brother 2820 constant paper jams
Most likely the fuser is worn out, and needs replacement
Jun 02, 2009 | Brother IntelliFax-2820 Laser Fax
Paper keeps getting jammed at the back
What happened is that the fuser has quit working properly. You would need to have the fuser replaced.
Mar 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Dell 1700 printer paper jams
if the paper is jamming at the back of the unit, and looks like an accordian after removal, it's more than likely only the paper sensor on the fuser. i dont recall the part number, but it can be had from online suppliers for under $40.
Nov 10, 2008 | Dell 1700n Laser Printer
Oki c5150 fuser jamming
This tells me the one of the Pickers in the fuser is damaged and causeing this Jam , I would replace the fuser and chaces are this most likely will resolve your problem
May 02, 2008 | OKI C5150n Led Printer
Minolta magicolor 2350 Laser Printer Logo
267 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
