Question about Car Audio & Video
Hi - I have taken a car radio from my daughters car - it is 2 years old - and I am trying to find out what hte many coloured wires connect to. I have identified the 8 wires to the speakers but what is hte colour code for the remainder - I have assumed red = positive and black = negative but what are the others Help
  • 92 Answers
When dealing with vehicle wiring, assume NOTHING! Your best bet is to go to a place that sells adapter plugs (wal-mart will probably even have them) and save yourself the hassle of trying to figure out the factory wiring. It will plug directly into the vehicle wiring harness and will have wire colors that should match exactly with most aftermarket car stereos saving you the guesswork. As an installer for over 15 years I have seen many attempts at wiring to a factory system without an adaptor plug and the results range from the system not working to doing major electronic damage to the stereo and even the vehicle.
In addition to it being a headache to try and figure out, many newer vehicles use some of those wires as data carrying lines and there are things in the factory stereo which control other things in the car ie: door chimes, air bags and others.
If you are hell bent on doing it the way you have started, please provide vehicle information and I can advise you further although I do not recommend doing it that way.
Posted on Oct 08, 2008
Radio displays locked after daughter tried 13 different codes Ford Fusion 11 years old
Did you try google or youtube? Chances are someone has already done this on your radio.
May 21, 2016 | Ford Cars & Trucks
Car stereo
go to best buy and get the sub harness the connects to your radio and plugs in to your car. then all you have to do is match the colors of the radio to hte colors of the sub harness
Mar 19, 2010 | 2002 Nissan Altima
I need to put a new sony stereo into my daughters Lanos and need to know what colour wires do what in the exisitng plug in the daewoo
Here are the wiring colors but just before you connect it please make sure the colors match
1999 Daewoo Lanos Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Dark Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Brown/White
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue/Black
Right Rear Speaker Negative Wire (-): Yellow/Dark Green
Jan 04, 2010 | Daewoo Lanos 1999 Car Radio/stereo...
Hi. trying to re-install a pioneer deck where an alpine used to be. can't read the japanese on the alpine wiring to know which wire is for what. What coulour goes to the ignition, what colour is for the...
dnt get confused, follow these simple wiring .......
firstly cut off the old lug from the connected place, make sure you cut each wire seperatly....and you are going ti use the wiring agin, avoid making the wires shorter...
YELLOW..12V+ DIRECT FROM BATTERY...can be joined where alpine yellow was conected.
RED...12V+ IGNITION WIRE..can be joined where alpine red was connected
Oct 30, 2009 | Alpine CDA-9851 CD Player
Running a uniden pc 122 4pin few yrs old wanting wiring colours
have a quick look at the link bellow that should sort you out
Regards Alan (alstech)
Apr 27, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Sep 27, 2008 | Midland 1001Z 40-Channels Base CB Radio
I need the colour wire description for a 2000 dodge caravan Im removing the the factory stero and installing after market stero and need wring diagram , what each wire is for ,speakers ,power etc.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Jul 17, 2008 | Car Audio & Video
Wiring colours and what they mean
Are you trying to use that radio in a different vehicle, or are you trying to find out what wires in your vehicle you need to connect to a new radio? Your best bet either way is to go to your local library and find the service manual to that make, model, and year of vehicle, and look up either the wiring diagram, or connector views of the radio. You can also buy conversion harnesses to plug a new radio right into your vehicle, so you don't have to splice wires. You don't want to just start hooking up wires because putting power or ground in the wrong spot can wreak havoc on the vehicle and the radio. Hope this helps.
Nov 25, 2007 | Car Audio & Video
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
