Question about Splendide Comb-O-matic 6200 Non-Vented Washer/Dryer
Splendide comb-o-matic 6200 door wont unlock
I'm staying somewhere that has one of these combo machines, and I've gone onto the website and there's no help for this problem on the troubleshooting page :( so anyway, the light wont stop flashing fast, and door wont unlock HELP!!
  • Anonymous Mar 01, 2009
    i have the same problem. this peace of **** sucks
4 Suggested Answers
gittos73
  • 244 Answers
SOURCE: Hello, I had an issue with the door opening on my Comb O Matic 6200
no most washers you can open the door by 1st unplugging it take the lid off now place your hand flat move it down on the inside of the washer the side that your door catch is situated now when you feel the interlock if you fiddle around with your fingers you will be able to open it some have a cable going to the inside of your interlock pull on this and that will open the door just got it have patience while you fiddle with it you will get it may take a few minutes but it will happen
Posted on Sep 24, 2007
I opened it with a pair of needle nose plyers. You gotta press down on whats left of the handle and pull out on the door. It's a little tricky, but that will open it.
Posted on Dec 24, 2007
  • 3 Answers
SOURCE: Splendide Comb-o-matic 2000 how do you vent it to the outside
Use 2.5" plastic pipe & elbow to replace aluminum elbow & hose with spring inside. Air velocity is higher, lint blows out without collecting.
I used wood router to remove part of exhaust connector on rear of dryer to better fit elbow. Elbow interior was smoothed to prevent lint sticking. Elbow was mounted with silicone sealant and 2 screws. Pipe was glued to elbow as normal glued pipe connection. Pipe end was cut even with side of dryer.
After Spendide was installed in RV, a union was stuck in from outside RV. Union slides on to pipe without sealant so Splendide can be removed from RV. Union better fills outside vent fitting than bare 2.5" plastic pipe. Temporary seal aroung union was made of urethane foam scraps, common shipping stuff from a computer monitor box. After 2 years of temporary, the foam is now considered permanent.
Original problem was constant lint problems in hose and slow drying. With pipe, not hose, lint is rarely cleaned and drying is much faster.
Posted on Jan 28, 2009
Water outlet hose replacement
Hi, you could try copper pipe, 22mm, or 3/4" (ish) ( plumbers) and jubilee (adjustable clips, from hardware store) to clamp the two together.
Dec 06, 2017 | Splendide Comb-O-matic 6200 Non-Vented...
Hi I am looking for splendida combo 6200 handle part. do you have it for sale?
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
for parts and service.
Sep 09, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
My motor yacht's Splendide Washer Dryer combo has nerver dryed the clothes
Thor Appliances - www.thorappliances.com - and LG both have machines that can replace the Splendide.
Aug 04, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
Need power button for Splendide Combination Washer & Condenser Dryer, model WDC1025MCEE or 6000
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 02, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Broke the handle and need to get it replaced
this is joyce,
How bad did you break the handle can it be glued back or will it have to be replaced, some times the entire door assembley has to be replaced , go to splendide.com and download your document on this paticular unit and look to see if it has a breakdown on the door handle unit and then you may be able to just order the handle.
thanks,
joyce
Feb 07, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Sep 24, 2007 | Splendide Comb-O-matic 6200 Non-Vented...
Splendide Comb-O-matic 6200 Non-Vented Washer/Dryer Logo
127 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
