Question about Motorola Mobility RAZR V3m Cellular Phone
How do I disconnect my phone from another Blue Tooth device?
  • speaker phone in the car does not work
  • Blue Tooth says it is connected to another device
  • did not connect to anything else]
  • how do I disconnect this other mysterious device
  • charlwill101 Jan 13, 2009
    I have a MOTORAZR2 V9 and when I go to the "Bluetooth Link" menu there is no 'current devices' option, only Find Me, [add audio device] and setup. when i go to [add audio device] it says "Bluetooth link is Busy. Phone is connected to another Bluetooth device"...
    but it's not! i've deleted all the bluetooth devices stored.
    what's going on?
    and does it make a difference between 'Always On' versus '3 minutes'...
    Master:
  • 383 Answers
Go to active devices menu in the bluetooth menu and delete any devices listed there and start find new device ... it should work fine ...
Posted on Oct 09, 2008
My Bluetooth and speaker connect but it wont stay on after one or two songs it keeps shuting down kicking my Bluetooth off on my phone
Teri,
I can't explain why this might work
but try this.
Disconnect the speaker from the phone's blue tooth by unpairing it
then reconnect the speaker by pairing it to the phone again for a fresh reconnection via blue tooth..
Had this issue with a Jabra blue tooth speaker on my wife's mobile phone was doing the exact same symptoms !
It was very very annoying but doing the pairing again fixed it .
Hasn't cut out since pairing it again !
Feb 03, 2017 | Cell Phones
When i try to pair with my galaxy tab s through bluetooth the tab goes through the process of connecting but doesnt pair however my galaxy s5 phone pairs immeditely ?
  • Your issue is that you can only connect one mobile or tab to a blue tooth.
  • It only accepts one device at a time.
  • You need to connect one to your blue tooth in your vehicle and try something like a blue tooth pill or blue tooth speaker.
  • I have had this problem with my Parrot car kit.
  • Hope this helps. Russell
Nov 22, 2015 | Cell Phones
How do you connect the onn mini speaker model BTS108
Search for the speaker from the device being used to connect!
Oct 15, 2014 | Audio Players & Recorders
How do I connect a blue tooth device that is already paired in my Samsung intensity 2?
Disconnect it first. means power off. unpair the device restart devices pair it again.
Oct 11, 2017 | Samsung Intensity II SCH-U460 Grey Verizon...
Set up for Blue Tooth
Please specify your phone make or model
Jan 17, 2014 | 2013 Toyota Venza
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
How to connect sony ericsion w395 via blue tooth
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
Motorola Mobility RAZR V3m Cellular Phone Logo
106 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
