Question about Dishwashers
My Insinkerator garbage disposal leaks out of a "weep hole " in the side casing when the dishwasher is draining. What is the issue?
  • 1 more comment
  • Anonymous Nov 28, 2008
    I have the same problem. there is a tiny round hole at the top of the garbage disposal almost like a piece of metal popped out. It is small maybe 3 mm in diameter and the water leaks out of it. I have a dishwasher hooked up to it too.
  • knotgoodenuf Jan 13, 2009
    I have an Insinkerator Badger 5 with the same issue. The leak is not at the dishwasher side input, the feed opening or the side drain. There is an apparent "weep hole" below the flange for the dishwasher input, but higher than the side drain that leaks. In my case it is not a drip, but a flow of water. Could this be related to a partially clogged drain line? The leak started after my disposal clogged and I used a plunger to get it to drain.
  • Anonymous Mar 14, 2009
    Sorry, but there is a weep hole.
I had the same problem. Turned out that the "weep hole" was a hole in the housing where the water pressure eventually popped a hole through the plastic housing. Replacement was the only option. Ours was a Badger 1.
Posted on Oct 05, 2009
  • 706 Answers
Hello Greenj,
I am not sure I unbderstand your problem based on the description you've provided but maybe I can explain the basics of your garbage disposal system. Most , if not all garbage disposal systems include a 'knockout' plug for side input of a dishwasher. There eran't any weep holes in any that I know of.. Just the feed opening at the top, a side drain opening that normally includeds a gasket and adapter to be tied into your drain system and a stub on the side ( near the top) that has a knockout inside in case you wantto attach the drain hose of a built in dishwasher to it. If that is where your seeing water leaking than and you do not have a dishwasher attached to it, then you may want to add a section of hose to it with a hose clamp and plug one end to keep water from leaking out. I don't know if I've helped you but I took a shot.. Hope this helps.. If so.. please rate this response accordingly.. Good Luck !
Posted on Oct 09, 2008
Leaking garbage disposal.is it time to change it?
If disposal is leaking from the tubular drain connection or leaking where dishwasher connects or at connection to sink, then those connections can be repaired.
If disposal is leaking from anyplace else, then replace disposal.
I wrote ez disposal replacement tips from when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 10, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 disposal is leaking from the side whats wrong
Check where leak is coming from.
1) Run water until leak starts. Use dry paper towel near top of disposal to see if sink strainer is leaking.
2) Move paper towel down and check where dishwasher connects to disposal.
3) Move paper towel down to tubular drain tailpiece.
4) Water should run down side of disposal if sink strainer, dishwasher connection or tailpiece are leaking. You can fix these problems using tips below.
5) If disposal is rusted out, then water will leak out of bottom or side of disposal body.
There are no repairs or repair parts for disposals.
I wrote EZ installation tips for garbage disposal from when I worked apartment maintenance that will save time and sometimes money:
Feb 19, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Just got brand new sink, there are two holes at the bottom side of it and when i run the water, water comes out the hole on the right?
there should be two openings at the bottom, one for the drain to the drain line, and one towards the top for a dishwasher to drain into the garbage disposal. If you do not have a dishwasher, the top drain should come with a cap, and the lower drain is what the drain pipe gets tied to.
Jan 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
What can I use to plug the dishwasher drain connection I no longer need?
Push a cork into the hole.
Garbage disposal doesn't have a lot of pressure pushing water out dishwaher tube until full sink of water is drained.
You might put gorilla glue or caulk on the cork to keep it in place.
Nov 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My InSinkErator Badger1 garbage disposal has started leaking from a small hole (round, ~1/8") about 2/3 of the way up the back of the case. It's particularly messy when the disposal is running. Is this...
Your drain is probably OK. The disposal is going bad. You can temporarily repair the disposal by using plumber's epoxy putty ( found at most home centers for about 5 bucks) to seal the hole. Sand the area around the hole first, and then dust it off. Use about a golf-ball size section of putty to seal the hole. This is not a permanent fix, but it will get you by for a while. Replacing the garbage disposal will be the ultimate fix.
If after repairing the hole the sink stands full of water, then you know for sure that the drain is backed up.
Sep 09, 2010 | Plumbing
I would like to know where the plug for the dishwasher drain in my new badger 1 disposal is?
#/4 of the way to the top there is a round pipe like thing sticky out from the side of the disposal...
Take a screw driver and pop the back out of the round hole to allow the water to get into the disposal...
Also dump the blank out of the disposal before operating it.
The just hookup the dishwasher discharge hose to the round hole and your are ready to go!!!
Heatman101
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I would like to know where is the plug for dihwasherdrain plug located ot he garbage disposal
It's not guaranteed that your particular model will have a dishwasher drain nipple, but it does, it'll be on the side, near the top of the machine. If the disposer is new you must knock out the plug inside the nipple before connecting a dishwasher. If the disposer doesn't have a nipple, you can get a piece of pipe to fit to the non-disposer side of the sink where you can connect the dishwasher drain hose.
Feb 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 InSinkErator and it is leaking, not from the bottom but from a leak hole in the top side middle of the unit. I can see the water coming out of the hole. Can it be plugged? the unit works...
There should be no leaking to the outside of the motor. If there is a weep hole, it would indicate there is a seal problem between the cutter blade shaft and the motor. Contact ace hardware and see if theycan give you a little more information on this unit.
Jan 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwasher drain fitting
if this was just put in it is most likely the packing plug was not removed when installed please take hose off and remove plug .
thank you for useing fixya
RATE ME
May 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Open Questions:
Dishwashers Logo
3,854 people viewed this question
Top Dishwashers Experts
