Question about HP LaserJet 1020 Printer
Attention Light Flashing
The attention light on my printer is flashing and I can't figure out why. I thought it meant I needed to replace the toner cartridge but I've done that and it's still flashing.
  • Anonymous Oct 17, 2008
    I also have the same flashing light. It all started with a paper jam.This was cleared. Now, when the "print" instruction is given for one copy only, it prints copy after copy until there is no longer any paper left in the tray. Restarting the computer signals the printer to print. Without paper in the tray, it will try to print 3 copies, and then shut down.
    Would uninstalling then reinstalling the printer solve this problem?
    Novelist:
    Scholar:
  • 111 Answers
Unfortunately, HP didn't make this indicator very descriptive. Their product specification page for this printer states that the blinking Attention light, "indicates that the printer media input trays are empty, the print cartridge door is open, the print cartridge is missing, or other errors".
You've already changed the print cartridge and the light is still blinking, so you should take a look at the other conditions described such as an empty paper tray, open door, and so forth. You also will want to look for a paper jam or carriage jam. These are two very common errors that will result in a blinking Attention light.
HP.com does provide a web page that describes a specific problem associated with a blinking Attention light:
Job Stuck in Queue
See if any of these suggestions work out for you. If not, post back your results along with anything else that you've learned about the problem. Good luck.
Posted on Oct 15, 2008
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    Light with the triangle flashing - printer stopped
    That means ATTENTION, you are either out of toner or have a paper jam.
    Feb 18, 2010 | HP LaserJet P2015 Printer
    The traingle is flashing orange the rest not flashing. the printer does not print
    In the Attention state, the Attention light is blinking and the Go and Ready lights are off. This state can be reached in the following circumstances:
    ● Paper tray is empty
    ● Door open
    ● Toner Cartridge Missing
    ● Paper jam/ Tray Misfeed
    Pressing Go attempts to reset after a jam is cleared or is ignored in the other error cases. It may be necessary to clear the error manually and press Go or close the top cover. If the error still persists, the device will return to the Attention state.
    Note
    The LJ1010 product series does not have paper out sensors. When the printer is in an Attention state because the paper tray is empty, the user must reload paper and press Go.
    Nov 13, 2009 | HP LaserJet 1010 Printer
    Blue light flashing light, red light on
    The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
    Jun 24, 2009 | HP LaserJet 2550n Printer
    Hp lj 2500 flashing yellow light
    The yellow-print-cartridge
    light is blinking, and the
    printer stops printing.
     The print cartridge is
    empty or missing.
     The printer cannot
    detect the print
    cartridge correctly.
    1. Reinsert or replace the print cartridge.
    2. If the print-cartridge light is still blinking but the
    Attention light is not on, turn the printer off and
    then back on.
    3. If the problem persists, repeat the above steps
    with yellow print cartridges until the error is
    resolved.
    4. If the problem persists, replace the printcartridge
    E-label reader, which is located on the
    pressure assembly of the print-cartridge
    carousel.
    Jan 09, 2009 | HP LaserJet 2500L Printer
    Flashing light
    Here is what HP has on the subject of the triangle light flashing:
    c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
    c00028328.gif Door open, media out, no print cartridge, or media jam
    The printer is in an error state that requires operator intervention or help. Check the following:
    • The print cartridge door is completely closed.
    • Media is loaded.
    • The print cartridge is correctly installed in the printer.
    • There is no media jam.
    Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
    13.JJ.NT JAM IN TRAY X
    The Attention LED is blinking. Check paper loading then open and close top cover.
    When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
    When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
    If the light pattern is different let me know (other lights on as well)
    -Hope this helps.
    May 28, 2008 | HP LaserJet 1012 Printer
    Hp laserjet 1320 problem
    This is an error state that is not described at HP site.
    Try to do a hard reset:
    1) Turn off the printer
    2) Press and hold down the green GO button
    3) Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
    4) Release the GO button.NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
    5) The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
    Hope it will help you
    Jan 24, 2008 | HP LaserJet 1320 Printer
    The red attention indicator light and the toner indicator light are both flashing together
    ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
    Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
    Thanks J
    Oct 27, 2006 | Kyocera Mita FS 1000 Plus Laser Printer
    HP LaserJet 1020 Printer Logo
    1,487 people viewed this question
    Ben Johnson
