Question about HP OfficeJet 6110 All-In-One InkJet Printer
I get the release button is stuck
Lights flickering and message that the release button is stuck
  • 1 more comment
  • dipietro06 Nov 05, 2008
    The carriage is in the far left position and is not movable. Holding the # & 3 keys simultaneously when plugging in the 6110, a message is displayed that says "button stuck release button". What button?
    Prior to this diagnostic message, a carriage jam message was displayed. We've cleaned & greased per other suggestions, to no avail. The problem occurred after I changed the black cartridge, printed a few pages & then tried to make a copy.
  • juliejesmer Jan 06, 2009
    Error message, "Release button is stuck" goes on and on in many languages. What release button?
  • Anonymous Jan 13, 2009
    Release button is stuck on my printer HELP
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
804
Posted on Feb 28, 2009
    Genius:
  • 1,605 Answers
What release button???
Posted on Oct 10, 2008
Volume will not turn up and will automatclly turn it self down when tv is turned on the volume bar is also pink
Take the battery/s out of the remote and operate the TV manually, if this works then its the remote itself causing the problem. Sometimes the buttons get stuck down and you need `flick` them with yor finger nail to release them. If the remote is quite well used then it needs taking apart and cleaning the contacts with a cotton bud and a non solvent cleaning fluid, this takes about 20 mins.
Also to test if the remote is transmitting, face the remote at a digital camera, if you can see a light or flickering in the viewer then you know its working everytime you press a button. If its flickering without touching it, at least one button is stuck down.
May 28, 2014 | Televison & Video
Ford explorer trac 2007 change the oil and filter and now have a wrench light on ,how resolve the problem
Sounds like you need to reset your Oil life/ maintenance reminder light. (also, double check your oil level)
To reset Oil life on a standard dash stlye:
1. pres and release the TRIP/RESET button until the message center displays SETUP MENU HOLD RESET
2. Press and hold the TRIP/RESET button for 2 seconds until the message center displays RESET FOR SYS CHECK
3. press and hold the TRIP/RESET button for 2 seconds until the message center displays OIL LIFE xx% RESET IF NEW
4. Press and release the TRIP/RESET button until the message center displays HOLD RESET IF NEW OIL
5. Press and hold TRIP/RESET button for 2 seconds and release to reset oil life to 100%
6. Message center will briefly display OIL CHANGE SET TO 100%
With a message center cluster the procedure is as follows:
1. press and release SETUP button until message center displays PRESS RESET TO BEGIN SYSTEM CHECK
2. Press and release RESET button until the message center displays HOLD RESET IF NEW OIL
3. Press and hold RESET button for 2 seconds and release to reset the oil life to 100%
4. The message center displays SETUP MENU HOLD RESET
Hope this is what you need/ are looking for. Goodluck & let me know how it goes, or if you have a different problem.
Nov 03, 2013 | 2006 Ford Explorer
No signal - stuck in Kansas
Try this and see if it fixes it for you...first disable bluetooth on your unit.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from problem.
Jan 02, 2009 | GPS
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
180 people viewed this question
Seeker5211
Seeker5211
