Question about Ricoh Aficio SP C410DN Laser Printer
Ricoh SP C410DN
My black toner is 3/4 full but the Printer keeps telling me it is not full and to replace it - now will not let me print. The supply mode on the machine though tells me it it also is 3/4 full. HELP
  • Anonymous Nov 18, 2008
    minha impressora esta com novo cartucho aparece uma mensagem dizendo que ela esta cheia mas nao é liberada para imprimir
    o que devo fazer????
Unfortunately the newer ricoh equipment may include a chip like the HP toner. This allows the printer to track the usage so the printer can "intelligently" determine how much toner remains in the bottle. The chip overides all other factors on the remaining toner. Hence, if the chip "thinks" that the toner bottle has little or no toner left, it will give you a false toner low message. Presently, you can only replace the toner with a new bottle.
Posted on Oct 30, 2008
What could be the problem on ricoh printer sp c420dn its given me error code sc 364
Probably you have just replace some of the toners (black). The toner density is too high. Restart printer and try to print full A4 black page.
Aug 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
Richo SP C410DN says black toner is empty, but just replaced...tried multiple toners...
Look at the toner hopper closely there are little springs that some times get caught "down" they line up with the contacts on the toner. -Carl
Jan 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
I have a ricoh c410dn and it has an sc364 error.
sc364 is a black toner density error. Typically, replacing the black PCU will get rid of the error message.
Feb 18, 2011 | Ricoh Aficio SP C410DN Laser Printer
Magenta toner is full but not printing pink
remove the toner and clean it and also check in the print option gray is not selected
Jun 15, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Aug 16, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh SP C410dn Paper only prints 11cm and stops in the Bypass T
do not use ohp film in this device as it will jam due to the use of optical paper sensors unless your ohp has a paper backing. you can set up the bypass tray for thick paper type to increase fuser temp to get better fusing etc
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Mar 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio  SP C410DN Laser Printer Logo
493 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
