Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
Hi-
2 Months ago I replaced the evap fan on our refridgerator (freezer working, refrigerator not). It has been working well ever since.
A few days ago the temperature alarm sounded and when I went to push the control button to turn it off I discovered that the control panel is not working - none of the controls respond when I push on the buttons. The refrigerator also seems "quieter" than normal - like the fans aren't running how they typically are supposed to. The temp seems ok in both the refrigerator and freezer, however, I am not noticing visible cold air rush out when I open the freezer and I always used to see it. I unplugged the unit for 5 minutes to see if I could get the computer to reset - no luck. Any suggestions on where to start?
Many, many thanks,
Brandon
  • 1 more comment
  • sheowe Nov 30, 2008
    same problem
  • ccmindyc Dec 17, 2008
    my kenmore elite is showing er If what does that mean
  • LaceAnn Jan 07, 2009
    I have a side-by-side Kenmore refrigerator with the same problem - the buttons on the control panel do not work. My fridge is operating but it seems to be stuck on the highest temperature and is freezing anything on the top self and is too cold for the fruits and veggiies in the lower drawers. Does anyone know why this is happening? Has anyone tried to have their same problem repaired? Thanks.
We have a
Kenmore Elite refrigerator Model 596.76533500The water dispenser stopped dispensing water. We changed the filter to see if that will help. It did not. Also, the ice maker eventually stopped making ice. What can we do to find out the cause?
Posted on Jul 30, 2011
I have this problem also my control panel is not working. It has an Er If on the panel.
Posted on Oct 13, 2008
Setting the controls
These are computer run items now. If you unplug it for 2 or 3 minutes does it reset itself? If not try pressing refrigerator an ice buttons together. If that does not work the evaporator fan or control panel needs to be replaced. That about all one can do these days other than keeping the air ways clean so fan is clear. But ecen that will not stop these voltage spikes on the line from ruining good appliances.
Jan 29, 2015 | Kenmore 27.6 cu. ft. French-Door...
Hi, Please tell me how to change the temperature on my elite kenmore.
Klay421 --
Which model Kenmore Elite refrigerator do you have? If you have one of the older manual models, the thermostat is located inside the fridge side. If you have a newer model with digital controls you need to press and hold the the ON/OFF button for 2 seconds until the digital displays for temperature for the Freezer and Refrigerator lights. The Up/Down arrows allows you to adjust the temperature. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Kenmore Refrigerators
Need replacement evap fan part# for Kenmore Elite
Head over to the manufacture's website.
www.searspartsdirect.com
Enter your full model number in, and you can see expanded diagrams and order parts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 27, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
Same problem.
okay, you will know it is a defrost problem if you see slushy ice on the back inner panel of freezer, if you do see it then your heaters are not coming on. you need to replace bimetal thermastat and heater.
2. In your freezer do you hear a fan running, you should hear a fan running, if not the air in your freezer is not pushing into the refridgerator, need to replace fan.
Sep 16, 2009 | GE Energy Star PDS22SIS Stainless Steel...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite Trio Model 795.7757960 - Error Code 'IF'
Hi!!! You have a control board problem.Change the control board and you should be okay..Them boards did'nt come out good.Good luck..
Jan 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator won't cool
We bought a Kenmore Elite Trio 596.76533500 from Sears in 2006. A few months passed and the Elite broke down. The tech person came out and found that the AC Evaporative Fan was inoperable. It was replaced (part #67003917). A few months later the same thing happened. But before they came out, I spoke to the tech person on the phone who seemed very familiar with the fan. He said that they've had numerous problems with that fan model and would bring out an older-type one that had fewer sensors and that was less prone to failure. The "motor evap" part #2214986 (Whirlpool compatible) was put in and everything has been working since... Hope this helps...
Dec 01, 2006 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
1,589 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
