Question about Home Fencing
Toro dingo has power at idle, but when going forward has no power and wants to die going up slopes.
3 Suggested Answers
backwoodsctr
  • 169 Answers
SOURCE: Toro Dingo TX420 steering is labored and stiff.
Dissaemble the steering and clean out the rust and corrosion that is causing the stiff steering. It would be cool to have a pool full of wd40 you could soak it in :) hope this helps. Let us know how it turns out
Posted on Nov 20, 2009
  • 1602 Answers
SOURCE: Toro dingo drives forward slowly but rev is ok
have you greased and oiled the machine, changed the oil. it sounds like the oil. the oil pump start to fail, causing metal to metal reaction,
Posted on Sep 16, 2015
My toro 17-44HXL model with a B/S 17HP engine stalls when trying to drive horizontally on a slope. It stalls when sloped either right or left side sloping.
The float in the carburetor might not be floating at the right height due to the slope. It's also possible fuel might not be reaching the carburetor as it hates to flow uphill. It's unlikely it has a fuel pump. Hopefully, it has an oil pump (and associated oil filter). Engines without oil pumps don't like inclines very well.
Jun 18, 2016 | Toro Garden
Sep 16, 2015 | Toro 2007 Dingo Tx420 Walk Behind Mini...
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
2002 explorer RPM gauge drops below 500RPM when in idle/park. Then the vehicle dies. HELP
The cable needs to be replaced their is a spring in there and that's shot
Apr 25, 2017 | 2002 Ford Explorer
Nov 20, 2009 | Garden
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro lawn mower it is a little hard to go forward but does go. It doesnt go backwards at all. Can you help me! Joanne
Check the drive belt for flat spots. If it is ok then it is probably an internal transmission problem
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Wont stay running
Hello:
Soak and Clean the Carburetor.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Home Fencing Logo
162 people viewed this question
Top Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Home Fencing Expert? Answer questions, earn points and help others
