Question about Konica Minolta DiALTA Di200 Copier
Minolta Di200f copier
This copier has a trouble code c0070 displayed, What is it. I added toner, but it displayed code before that. I powered it down and then powered it up and reinstalled the toner, being careful to keep UP at 12 o'clock. It will warm up and try to copy, but the paper gets hung up where it exits machine in collector tray. HELP!!
  • Konica Minolta Expert
  • 1,326 Answers
The error code has to do with the toner bottle/hopper. You just adde toner Right? Take the new toner bottle out and make sure not to spill any. Then close the doors of the copier and turn the main power switch OFF then back On. Let the copier warm up to Ready toCopy. Then reinstall the toner bottle and that should do it for you. The toner was out of HP when the toner was replaced. ... Good Luck
Posted on Oct 09, 2008
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Minolta Copier Bizhub 1263/211Problem
C 0070 toner bottle mechanism defect.Remove the toner cartridge and clean using a vacuum cleaner the toner botle house and the sensor.
Mar 24, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0070 konica minolta copier service code c0070
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Feb 05, 2014 | Konica Minolta DiALTA Di200 Copier
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Copier malfunction
Have you just added a new toner? If so try this first.... Turn the power off and carefully remove the toner bottle you just put in.. Close the front door and turn the power back on and let the copier warm up to ready. Make one or two copies and open the front door and reinstall the toner bottle again... That should take care of the problem.... If it dose not work you probly have more of a major problem with the hopper unit..
Jun 18, 2009 | Office Equipment & Supplies
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Jan 24, 2009 | Office Equipment & Supplies
Minolta CS Pro Error Code C0070
Turn on and off WITHOUT toner bottle inserted to reset to home position. If message comes back, the toner motor/drive gears are busted. Time consuming repair, be warned!
Dec 07, 2007 | Minolta Di3510f Bizhub Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
Konica Minolta DiALTA Di200 Copier Logo
277 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
