Question about RCA P52926 52" Rear Projection Television
Sound messing up on TV
My problem ranges from a very lound staticy buzzing sound to no sound at all when I try to watch TV. I tried someone's suggesting of unplugging the unit for a couple of hours. It worked for a while, then went back to the really loud buzzing sound.
I tested it both with, and without the cable box.
Interestly though, it gets perfect sound thru the DVD.
  • 3 Answers
Well this may not be that helpful, but if you decide to give up, you can always run the sound through your surround system or plain old stereo, and there are many ways of doing this
Posted on Oct 29, 2008
Buzzing sound car stereo
A lound buzzing sound is an indication that the Driver (transistor) for the amplifier final is bad. This is not so much a buzzing and it is extreme in loundness.
May 05, 2013 | Chrysler concorde amplifier. radio. ....
Speakers sound staticy and computer runs slow
Definitely sounds driver related. Be sure to completely uninstall sound drivers and controllers from Device manager, and reinstall directly from manufacturers web site. If this doesnt fix it could be a bad connection.
Sep 18, 2012 | Dell OptiPlex GX520 PC Desktop
I have a Samsung HLN617w that has an awful buzzing noise that seems to be continuous and maybe from the lamp fan. Any suggestions on a fix?
This tv have a colors wheel is dying and worn out.The sound u hear buzzing,squiling or lound motor noises.The colors wheel require changing,because it dying and spinning off of it motor axis.Hire a tv Tech. to change the colors wheel,because it sit way inside near the Light Projection Engine it self,require take out many machanical parts even can come to the colors wheel itself to change it.
Nov 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although FixYa.com (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
Mar 18, 2010 | Samsung HLR5087W 50" Rear Projection HDTV
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Loud buzzing sound
It is the color wheel. They are usualy less than $150. I recommend having a Samsung authorized service center do the work as it is very difficult for someone without the experience doing this particular job. Labor cost should be $300 or less.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Technics sax-710 receiver Nht sb-1 speaker developed a buzzing sound when playing, Kids may have over drove speakers(not sure) Replaced with nht supezeros now both speakers sound very staticy like off...
The speakers have buzzing sound because of damaged cones.
Over driving speakers, especially with heavy low frequencies, can tear the voice coil away from the cone.
Once damaged, only replacement will help
Apr 24, 2008 | Audio Players & Recorders
RCA F32650
I let it go and she corrected by herself. What do you think?
Aug 14, 2006 | RCA F32650 32" TV
RCA P52926 52" Rear Projection Television Logo
83 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
