Question about Jenn-Air JED8430 Electric Cooktop
Dual Element When I turn the dual element on High, either the large or small element, it does not completely turn red. There is a pie shaped part that remains black. If you think of the element as a clock, the area between 3 and 4 is the part that stays black
    Genius:
  • 1,605 Answers
Check underneath the element, you may have something preventing the element from gihting up. if you didn't find anything, then it is time to get a new element.
Posted on Jan 08, 2009
How to replace an element
This could be a couple of issues, but unfortunately if it's your element, you would have to replace the entire element, not just the middle part. What's the rest of your model number? I can find a part number for you. (KECD806R****)
May 17, 2014 | KitchenAid KECD806R 30" Electric Cooktop,...
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
My large dual burner does not heat up completely. Only the center burner works
The only way to find out the problem and repair it is to disassemble it..
Most have to be disassembled from the bottom, with the unit pulled and laying on a blanket to protect the top.)
Could be a bad switch, a bad element, or a wire is burnt off.
Good luck....
Apr 08, 2010 | GE Cooktops
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 | Cooktops
The dual element does not hold at medium heat.
repl the sw / not a uncommon repair .. mm . element is ok .. sw's are geting better ..
Dec 06, 2009 | Amana 29 in. ACC4370 Electric Cooktop
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
Burner gets hot even when not turned on
sound like you have a shorted element, it will stay hot but not high heat hot (glowing) red, other posibility is bad infinate control switch that switch could be bad
Apr 13, 2008 | Cooktops
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
Jenn-Air JED8430 Electric Cooktop Logo
118 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
