Question about Panasonic KX-T7633 Corded Phone
How to forward incoming calls
How do I forward an incoming caller to someone's voicemail?
    Scholar:
  • 38 Answers
There is a feature that most dealers do not activate called "Voice Mail Transfer" which transfers an incoming call to a person's (or department's) voice mail box. Forwarding calls to someone's mailbox is not possible without special programming by a certified dealer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
I have a Uniden D3097. It is ringing only once on incoming calls. I have called from a different phone and it rings several times for the caller then goes to a generic VM not the VM I set up.
By any chance do you have call forwarding turned on? That would account for the single ring and the unfamiliar voicemail. Call forwarding is a service provided by your phone company or cable voice company which allows you to transfer incoming calls to another phone number, such as a cell phone. It's usually activated by pressing a key sequence (such as *72) and entering the number of the phone that you want to receive your calls. It's easy to turn it on and then forget to turn it off. You can turn it off with another key sequence, such as *73. Contact your phone company for the correct code.
Aug 12, 2014 | Uniden D3097 LOUD & CLEAR Cordless Phone -...
How do I set up voice mail
Call services From your phone, you'll be able to access and change the settings of various call services for your phone.Contact your mobile operator to find out about the availability of call services. From the Home screen, press MENU and then tap Settings > Call. Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings Edit the call reject message, choose whether to open the message editor when you reject a call with a message, and choose whether to allow automatic saving of an unknown contact number when a call with that number ends.
Cell broadcast Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings Configure channels and language for cell broadcast messages.
Call forwarding Select how you want your phone to handle busy, unanswered, and unreachable calls. You can also set the call forwarding option for all incoming calls. Call barring settings Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
Jun 28, 2011 | HTC Inspire 4G Smartphone
Why does another extension ring at my extension
Someone thought it'd be a good idea for your extension to back up that extension when answsering incoming calls, or their extension is forwarded to yours. Either cancel the call forwarding with the right code (be careful not to remove forwarding to voicemail), or have someone remove the program on your extension which makes you a backup to the other one.
Jul 01, 2010 | NEC Electra Elite DTU 16D-2 Corded Phone
LG CHOCOLATE: identify phone number of incoming voicemail
try transferring the calls from ur mobile to the voicemail when u r not available....
in call settings u might have an option of forwarding the incoming call after so many particular number of rings... forward the calls to ur voicemail numbers using this and then u ll have the numbers in ur recieved calls list.
this might work but is only a temporary solution
Jun 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
How to forward a call to a virtual voicemail box
With the caller on the phone, press a "Voicemail Transfer" button, then the extension number and hangup.
OR
With the caller on, press FEATURE 14, then the extension number and hangup.
May 19, 2010 | AT&T Lucent MLS-12D Phone
IPhone doesn't receive calls
just found this on the internet...
Toggle airplane mode: Tap Settings > Enable Airplane Mode, wait five seconds, then turn off airplane mode. Check your phone settings: Check your Do Not Disturb settings: Tap Settings > Do Not Disturb. ... See if Call Forwarding is turned on: Tap Settings > Phone > Call Forwarding.12 Nov 2013
I am not receiving incoming calls on my iPhone ... ' Official ...
https://discussions.apple.com/thread/5552399?tstart=0..
or try this link..
IPhone doesn receive calls Google Search
Oct 27, 2017 | Apple iPhone Smartphone
INCOMING CALLS
Hi there, it is possible that you have the G1 set into "always Forward" state, which means when receiving calls the phone will forward the caller to your voicemail.
To Check and change these settings. goto the G1's Home screen, Click the "Menu" button, and then click on "Call settings". Then from here click on "Call Forwarding".
From here, the top setting should say "Always Forward" If this is set to Enabled, click on it and select Disable. This should now allow you to receive calls correctly ! if the Always forward function was disabled already, i would suggest calling T-Mobiles Customer support line to see if they have a remedy to this situation !
Hope this helps ?!
Oct 27, 2008 | HTC G1
Mitel Superset 4025
Is the Call Forward No Answer turned on? Is the voicemail working on other phones, just not this one? If you can verify this I can probably help you.
Jul 18, 2008 | Mitel Superset 4025 Corded Phone...
Iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Jul 17, 2008 | Apple iPhone Smartphone
Not recieveing incoming calls go straight to voicemail
call cricket cause sometims that would happen to my phone but it was just because they messed up my bill and got it confused with someone elses
Mar 13, 2008 | Kyocera KX444 Cellular Phone
Panasonic KX-T7633 Corded Phone Logo
494 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
