Question about FUJIFILM FinePix S4000 / S4050 Digital Camera
Why is my camera saying "turn camera off then turn back on again"
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 116 Answers
Your camera probably has a Lens Eror.
Posted on Oct 04, 2012
SOURCE:
Sony dcr-s100 says format error
Try another drive and see if does the same thing. If so your unit is bogus. If not, the first drive is bogus and maybe a format will restore it. Not like you have much choice.
Aug 28, 2017 | Sony Handycam DCR-SR100 Camcorder
My Nikon coolpix S10 camera was dropped and now the screen only says "lens error". If it is not touched the function returns to normal (has done so twice), but now the screen only say that one...
try this out it worked for most of them who had a similar problem like urs:
Gently tap it twice at the end of the camera to ur plam and it will work again.
just tap it very lightly against the bottom of the camera holding it upright
Goodluck,
May 11, 2008 | Cameras
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Oct 12, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
Camera will not come on, it says "turn the power
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Jun 19, 2011 | Sony Cybershot Dsc-w290 W230 W220
I turn my dmc-fh27 camera and the lens won't come out. it is trying to move but it will not budge and the screen says "System Error (Zoom)".
Warning: This is only a last resort if you no longer have a warranty.
I used a variety of different methods, but here's what worked for my camera. Apparently the lens was just off the track.
1. Turn on the camera, and smack the back against the palm of your hand to get the lens to come out.
2.Hold the lens out until the "error screen" comes up.
3. Take the camera with the lens facing towards you, and use your thumbs to push on the lens.
4. Push firmly until the lens "clicks".
5. Turn off camera, then on again.
6. Hopefully cry tears of joy that you fixed it.
Jun 12, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
When i turn on My Kodak 1033 in screen displays "Memory card requires formatting".When I done formating it turn off. I try to turn on again it says this "Memory card requires...
Have you formatted the card from the camera or the PC ?
If you have done it from PC, do it from the Camera and it should work.
Regards,
Ron
Feb 25, 2011 | Kodak EasyShare M1033 Digital Camera
My Cyber Shot DSC W55 when i open it the lens keeps moving forward and backward and then something shows on the screen which says First "ACCESS" then the next one is "Turn The power off and...
Error: TURN THE POWER OFF AND ON AGAIN or Access is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 24, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
When I turn on the camera the screen says " card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 14, 2010 | Samsung Digimax L60 Digital Camera
When turning on my sony dsc- w55 camera, the lens retracts and goes back in. screen says "turn the power off and on again"
turn on gently hold end of lense and pull and twist gently you may here a click but dont force it
turn off and on again and it should be fine
hope this helpps
Sep 07, 2008 | Cameras
FUJIFILM FinePix S4000 / S4050 Digital Camera Logo
132 people viewed this question
Top FUJIFILM Cameras Experts
Falling star
Marvin
Marvin
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
