Question about Whirlpool GHW9100L Front Load Washer
Ghw9100lw front loan no diagnostics
Cannot get whirlpool diagnostics to run. Followed protocol on tech sheets. Lights on. Hear the 4 beeps.
    Genius:
  • 1,028 Answers
Change main control
Posted on Oct 09, 2008
Whirlpool Duet GHW9100LW wont spin. Drains fine, but no spin.
see this causes and fix it. God bless you
Door Switch
This can cause the washer to agitate but not go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer door will not lock. Get a DLF default code
If you remove the kickplate thats located in the front lower part of the machine you will find a tech sheet in there with directions on how to activate the diagnostic mode and have the machines cpu run test on all the parts and tell you what the problem is
May 18, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet washer is making a sounds like its running, but no lights are on and door is unlocked. I've trying pushing and holding buttons to no avail
Your tech sheet is below inside the service panel. Consult that tech sheet to see what errors are in diagnostics. Check the pump filter.
I have a manual HERE
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is a f9 error?
"F09" is an Overflow Condition error. The following link explains how to diagnose the problem yourself:
http://www.fixya.com/support/r3608557-f09_error_code
Read through the information provided and check all the common sense things that you can easily eliminate, first. For more in-depth troubleshooting procedures, refer to the tech sheet that came with your washer. The tech sheet is located inside your appliance. To access, remove the lower toe panel under the door by removing the screws under the bottom front edge (you may have to prop the two front feet of the washer up for better access - a 2x4 works well for this). With the screws removed, the panel will drop down, then come off.
The tech sheet will either be located directly behind the toe panel, or affixed to one of the interior cabinet walls. The tech sheet includes troubleshooting tips, error code definitions, test points, diagnostics procedures and wiring diagrams. You will need to use the tech sheet to accurately locate and perform some of the steps I have outlined.
If you have questions about this repair, please post back and let me know. I hope this helps you.
Mar 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Just installed whirlpool duet front load, no lights, no display
sounds like whirlpool, but yes is not an error code. try diagnostics, press any option key 4 sec on 4 sec off 4 times from off and should enter diagnostic and show real code
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GU1200xtks0 Blinking Lights
Try pressing heated dry, normal, heated dry, normal keys within 6 seconds. All lights should come on and the machine should enter diagnostic mode. If this does not work remove the 2 screws that hold the toe panel on at the bottom front of the dishwasher, attached inside you will find a tech sheet that tells you how to enter the diagnostic mode. Once you get it in diagnostic mode let it do it's thing, will take about 20 minutes total. At the end the control will be reset. If the fault comes back then troubleshoot according to the tech sheet, or call for service.
Feb 20, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool duet how to enter diagnostics
look for tech sheet. this will tell you how to enter machine into service mode. Its located either behind bottom kick panel. or under top panel.
Feb 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE3T door lock
you can try removing the lower aceess panel, behind there ,usually tapes to the inner wall is a tech sheet/ diagnostic chart. inthere it will explain how to check each component individually. there s a master diag mode, im not sure how to enter with the sears version, only familliar with the whirlpool(same machine different control panel)it will test all components though
Apr 21, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
