Question about Corona 23-DK Compact Heater
Corona DK 23 will not light; switch is upside down!
I just put in a new wick, and new batteries. The coil lights and moves to where it's supposed to, but there is no sign of the wick.
I can see that the dial is now upside down. That is, it used to turn clockwise, from left to right in an arc above the dial; and to shut it off, counter-clockwise, from right to left in an arc above the dial.  Now, the switch is backwards -- to go from off to the lighting position, it makes an arc UNDERNEATH the dial, and UNDERNEATH the dial to the shut off position.
When I installed the wick, it worked fine when I tested it. Why did it change?
  • eridon Oct 09, 2008
    I disassembled the heater again, down to removing the wing nuts so I could re-insert the wick assembly and make sure the dial is at the up position and re-set the set lever.  The wick is still too low for the coild to light it.
    There surely must be a set screw somewhere to re-align the wick, but I can't find it.
  • eridon Oct 10, 2008
    The knob is now working fine. I had to take it apart again, down to the wick assembly, and make sure the wick was at its highest point before putting it back together, with the re-set newly set -- and that's what did it.
    Now, I still can't get it to start. The igniter is not close enough, and yet the wick is where it should be and the measurement between the top of the wick and the pins is the correct 2 and 1/4 inches.
    Don't know what to do except try and start it with a match.
  • 39 Answers
Watch using matches to light a heater like this there dirty and cause problems in the long run long lighter for grills will save from extra garbage getting in the heater
Posted on Dec 14, 2008
Is it possible to manually ignite a corona 22dk kerosene heater safely with a butane lighter? the battery operated igniter is not working with new batteries installed.
I just use a match. Turn the setting dial to High. Open the little door in front. The one with glass in it. Light the match. Push the pedal down that you normally use to start it with the battery starter. Put the match into the heater and touch it to the wick. With just a regular match, I can reach in far enough to light the wick. When you have a complete ring of fire, lower the pedal slowly and close the door. It will smoke briefly and then burn. After 15 minutes lower the wick till the flame is smaller and whiter.
Sep 13, 2010 | Corona 23-DK Compact Heater
I have a 23-dk corona kerosene heater. it was smoking so i replaced the wick. after replacing the wick it still smokes heavy. how do i fix the problem.
Check all airvents into conbustion chamber. Make shure they are all clear of blockage. The heater needs air to burn fule properly. Check wick adjustment it may have to much wick.
Sep 03, 2010 | Corona 23-DK Compact Heater
The wick will not raise
If you allowed the fuel to run out then the wick is probably ruined, you will have to replace it.
Feb 26, 2010 | Corona 23-DK Compact Heater
Corona 17 dk
Just pull it out with pliers. It has sharp directional tabs pointing down holding it in. Once the wick is pulled out, it is no good. New wick pushes right in.
Apr 03, 2009 | Corona 23-DK Compact Heater
DynaGlo RMC-95-c6
did you soak the new wick a good hour in clean kerosine before you installded it???is your wick in the correct position? it needs to be 5/8" showing when installed in the up most position.very important to soak the wick or it won't wick up fluid as it is suppose to.
Feb 24, 2009 | Corona 23-DK Compact Heater
Corona 23-DK wick replacement
yes the sleeve comes out and ther should be a couple little barbs holding the old wick in.fold the new wick to put it in making sure the adjustment pin is in the right place on the sleeve then slide the whole thing back in making sure to get the adjustment pin into the nob while sliding the sleeve an wick down
Dec 27, 2008 | Corona 23-DK Compact Heater
Kerosene heater
Turn knob all the way to the right. Your wick may not be mounted right. The pins are out of the guiding wholes.
Nov 14, 2008 | Corona 23-DK Compact Heater
Corona DK 23 kerosene heater won't start
try bringing your wick up to the fully raised position and pinch and bend the wick toward the igniter until they line up right. I have two coronas one of which has a broken igniter due to wear and tear. If you open the little door,press down the start lever,and light the wick with a barbecue grill lighter,you can safely light the heater if lining up the wick fails.
Oct 09, 2008 | Corona 23-DK Compact Heater
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Corona 23-DK Compact Heater Logo
152 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
