Question about Brother Office Equipment & Supplies
On the screen of my Brother MFC-8440 it says to Pls Clean Drum. What do I do to fix it because the machine will not work?
  • 928 Answers
If you need additional instructions just message me.
Posted on Oct 08, 2008
Just installed a new drum unit in my Brother DCP1000, and it's still reading "Replace Drum soon"
heya!
this stands for brother mfc-8440 as in the title.
you need to reset the "drum counter" of your printer..
to do so try one of those
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
Brother Fax Machines:
Open the front cover. Press the CLEAR/BACK button. Press 1, when the display shows accepted.
Sep 19, 2011 | Brother MFC-8440 All-In-One Laser Printer
WHEN I TURN ON MY MACHINE BROTHER MFC 8440 I SEE ON THE SCREEN ERROR MACHINE 6A I NEED A SOLUTION
Error factor: Heater warming-up timeout error.
(Heater does not reach 60°C within 11 sec.)
Check: • Thermistor ASSY
• Halogen lamp
Jan 08, 2011 | Brother MFC-8440 All-In-One Laser Printer
How do i reset the drum on the brother mfc 8440
Open Toner front cover.
Press Clear.
Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO
ACCEPTED.
Jan 22, 2010 | Brother MFC-8440 All-In-One Laser Printer
How do I clean the drum on the Brother MFC-8440
It should be constantly cleaned by it's cleaning blade with every revolution. If that's not making continuous contact inside the drum unit, then it's time to replace the drum. The symptom to look for is not just a gray background, but images that repeat about 3 inches down the page as the drum rolls around to that point again.
If the background is gray without noticeable repeating image, it may be a defective toner cartridge. We've wasted a fair amount of money replacing Brother drums when it turned out to be the much cheaper toner cartridge. If it's a new cartridge, take it back to the store along with before and after print samples.
Jan 21, 2010 | Brother MFC-8440 All-In-One Laser Printer
Installed new drum on Brother MFC-8440. Still says chnage drum soon
With new drum you got to have a instruction how to reset counter of the drum. In every packet of new drum come with instruction how to change and reset.
Dec 15, 2009 | Brother MFC-8440 All-In-One Laser Printer
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
Aug 03, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
