Question about GE JVM1650 1000 Watts Microwave Oven
GE Eterna Microwave
I need to separate the two inside glasses on the door to clean the inside. I have the door off but can not figure out how to separate the double pains of glass - please advise
  • GE Master
  • 9,098 Answers
Hopefully you didn't disturb the hinges to remove the door, since that will require alignment and testing to be sure it is not leaking.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 20, 2008
Steam got inside door of microwave behind glass. Now there are white spots where water dried. How do I clean the inside?
Look and see if there are screws holding the inside of the door to the outside of the door.
If so, remove the screws and the door should come apart, and may be cleaned.
God bless your efforts.
Jun 29, 2010 | GE HVM1540SNSS Microwave Oven
Clock works panel lights up but it won't heat
All of a sudden last nigh it just started acting weird the panel works and the clock etc works as well as all the cooking setting. but it doesn't light up inside and when I close the door to my GE Profile Eterna Space maker it starts huiming like its cooking something
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Grid in door is discolored,rusty looking,moisture build up on gla
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Moisture can show up if a filter is clogged or air flow is otherwise limited or blocked.
You can download GE owner's manuals and installation instructions here.
Feb 03, 2009 | GE Microwave Ovens
Clean between mesh and glass on microwave door
Dec 04, 2008 | Whirlpool MH7140XF Microwave Oven
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Clean the inside glass
Or you can watch a YouTube video (not a video I made) here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 21, 2008 | Maytag MMV4205 Microwave Oven
How to remove the outter door frame on the GE Microwave
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
GE XL1800 Door
OK, I'm no handy man and I just figured out how to do this. Open the door and remove the black plastic cover surrounding the inside glass. I used a regular flat head screw driver to pop this out.
Now I removed the 3 screws holding the inner panel against the glass on the front door. After removing the screws, the inner panel is held in place by a series of plastic clips. Go around the perimeter and pop the plastic clips out so the inner panel including the mesh comes out of the door.
Now you have complete access to clean the inside of the glass door!
I found it easier to do this operation with the door completely off the microwave, but you should be able to do this with the door in place too.
Aug 27, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
273 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
