Question about Whirlpool Duet GHW9150P Front Load Washer
HF alarm HF keeps showing on panel during rinse cycle and i have to restart several times to get cycle to finish
    Genius:
  • 1,028 Answers
1st ck all hoses and screens for blockage be sure you have good water flow to washer next remove top ck flow meter left side 2 small hoses 1 in one out may be able to tap it on the side and temporaily correct problem best bet is to replace it
Posted on Oct 09, 2008
Won't finish cycle
The water may not be getting hot enough in the rinse cycle. Usually it needs to heat to 140 to 160 degrees for rinsing. If the heating element is not working the water will not heat. If your DW has a Sanitary setting it will be calling for the water to be 160 degrees. If you have the option to override the Sanitary settin, try that to see if the rinse cycle will finish with cooler water.
Mar 27, 2010 | Dishwashers
I get error F1 every time I start and before the rinse cycle. I will change cycles, change settings within cycle menus, it tales at least three attempts of shutting it off and restarting it. Now it will...
here's the part # W10189966. I guess whirlpool had a recall on the units and revised the control boards. might want to call whirlpool on that. Good luck :)
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
During rinse cycle, washer just stopped, and won't continue rinsing/drain/finish
Have you tried restarting the cycle? If so, does it stop at the same exact place in the rinse cycle? If so, the issue is most likely the timer mechanism (cycle control) that needs replacing.
If it doesn't stop at the same place, it may be a flaky lid switch.
Jul 09, 2009 | Washing Machines
I put liquid dishwashing soap IN THE RINSE AGENT DISPENSER. What can I do?
I suggest purchasing a pipette (long thin flexible plastic eyedropper thing) from hobby lobby, Frye's, or from a scientific lab supply.
Draw up as much a you can from inside. Apart from that unless you remove the panels from the door to access the reservoir, then it may take several more washes to remove the soap from the the rinse additive dispenser. One more thing, you could start the machine in the rinse mode to wash the dishes and stop it when done and restart in the wash mode to rinse. When that is finished, stop and restart in the drying cycle. Good Luck!
Jul 03, 2009 | Dishwashers
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
346 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
