Canon smartbase mp370/360 print cartridge jammed
  • Anonymous Nov 22, 2008
    "wrong cartridge "message----same cartridge had previously been printig ok, fitted new cartridges -now won't print anything. smartbase 360
    New Friend:
Canon MP360S cartridge jammed. Stuck over on the right side. How do I get cartridges to move to a point where I can get them out?
Posted on Jan 15, 2010
SOURCE:
My Canon Smartbase MP360 will not print and shows 'put in cartridge' which I have done and it makes no difference.
sometimes a little bit of dried ink stops the flow of ink
use a cue tip and genty clean both the puter contacts
and the cartridge contacts then try again
after resetting do the head cleaning tht the machine can do for itself
this work most of the time
hope it help ps watch and dont let any fuzz get left behind
Aug 22, 2012 | Canon SmartBase MP360 All-In-One InkJet...
I keep getting a "wrong
Clean the print head/cartridge with Isopropol Alcohol (rubbing alcohol)and Q-Tips, The nozzles, the contacts and all the excess ink that had acummulated around the nozzles. The error message should clear.Run through all the maintenance checks and alignments. If this does not fix it, the print head needs to be replaced about $45-$60 from Canon.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 20, 2011 | Canon SmartBase MP730 All-In-One InkJet...
Canon smartbase MP360 "put in cartridge" does this means buy a new in this case printerhead. The printer was printing fine before this error message came up and printing stopped. Amazing another clean...
Print heads cans wear out. Put in cartridge sound more like a low ink level. Check ink levels and reseat the ink cartridges. Still no? I'd suggest having the print nozzles checked by a repair center or Canon.
Oct 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon Smartbase MP360 showing error code ##336
It seems the home position sensor is out of whack or the mylar band behind the print cartridge carriage is missing or broken.
To find the mylar piece look for a clear 6mm x 460mm clear piece of plastic with black markings (like a gradient) on both sides.If you find it you can try and place it back by looking for an extended eyelet on both sides of the stell print carrier.
Most people in haste to change ink have the hand slip and it becomes dislodged.
Jun 17, 2009 | Canon SmartBase MP360 All-In-One InkJet...
KEEPS COMING UP WRONG CARTRIDGE ''''336
with machine switched on ok hold down the stop reset button for 10 seconds it will bypass the sensor and should be fine. happpy printing
Canon Tech
Apr 01, 2009 | Canon SmartBase MPC400 All-In-One InkJet...
Smartbase MP390 Printer - error ##345
canon smartbase mp390 error ##345 check printer can anyone help me
Nov 01, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Printer problem
I did a few quick searches, and found this.
http://www.fixyourownprinter.com/forums/inkjet/32640
It pretty much says that your print heads are messed up or you have a jam inside the printer. Depending on the level you want to get into taking a part the unit you may wish to purchase another one or take it into a big box store to be shipping to a service center or call canon and as for the nearest one. However according to the post here, you can soak the print heads in warm water over night to clean them. However most likely there is an object blocking the cartridge.
I hope this helps.
Nov 30, 2007 | Canon SmartBase MP390 All-In-One InkJet...
##345
Hi, Apparently that error code means that the the cartridge is jammed, check that there are no bits of stuff stuck there and try to maybe remove the cartridge and maybe if you have any realigning software run those on it.
There seems to be a lot of people with the same and similar problems and the Canon service tech didn't seem to know what to do, and most are out of warranty too.
Let me know how you go.
Nov 21, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Canon mp30s cartridge jammed
Since making my query post my husband seems to have solved the problem. I first tried the solution offered here for another printer model (remove then replace actual print head unit with the cartridges intact) but that didn't help. So my husband put a small amount of WD40 (also known as CRC) on the slide bar that the print head moves along. That seems to have freed everything up.
Oct 10, 2007 | Canon SmartBase MP360 All-In-One InkJet...
639 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
