Question about HP Compaq Presario v3000z Notebook
Color brightness all the sudden the colors all seem very bright and dull, I haven"t changed anything, and when I compare to my daughters I have no color where it should be. How do I fix this?
  • 186 Answers
First of all, if you are barely able to see the display and if it is too dull to use, the Backlight of the LCD might need to be replaced.
However, if the display is bright enough and issue is the colour, the Cable that connects the LCD to the Motherboard might have gone bad and needs to be replaced.
I recommend you to get your computer examined by a service technician and get the necessary repairs.
Hope this helps...
Posted on Oct 18, 2008
My laptop display very dim
If your HP laptop has a dull screen, or if the screen is too bright to make out anything that's displayed, you may need to adjust the brightness to get your screen back the way you like it. You don't want to strain your eyes to see your screen, and the fix is really simple. It's about as easy as adjusting the brightness on a TV. You'll have your brightness set the way you want it in a few seconds.
1. Right-click on an empty space on the desktop and a drop-down menu will appear.
2. Click on "Properties." If the HP laptop uses Windows Vista, you'll click on "Personalize."
3. On the "Personalize appearance and sounds" screen, click on "Window Color and Appearance."
4. Click on the arrow beside "Show color mixer."
5. Use your mouse pointer to move the tab on the "Brightness" scale to the left or the right to adjust the brightness and click on "OK" when you're content with the color.
I hope you find it very helpful. Thank you for using fixya.
Best regards.
Aug 15, 2011 | HP G62144DX Laptop
The lights of my 1996 toyota corolla is very dull as compared to the newer cars. I want to make it brighter how can I do it please advice. thanxs
if the bulbs are H4 you can try buying XENON gas filled 55/60 watt with a temperature heat color of 5300K they give of a very bright white light, but make sure that your lights are getting 12 volts to the lights first,if they're not it could be the reason that they are dull,a lot of european cars have XENON H.I D light systems fitted to them this is why they look so bright, but these are expensive......hope this helps....cheers
Jul 10, 2011 | Toyota Corolla Cars & Trucks
I have a problem with the color of the pictures that comes out of my canon dslr 400d rebel xti. when i take pictures and compare it with other canon dlsr, my picture looks dull and lifeless. it also the...
hi there,
the common difference between canon and nikon is the color they produce. you can try to change the White Balance setting on your Canon to the suitable mode e.g cloudy, tungsten, daylight, etc.
if you still feel that the picture is dull, don`t be shy to use graphic software such as Adobe Photoshop, Picasa, etc. to enchance the color/brightness/contrast of your picture
hope this will help
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I have Sanyo 42" flat screen LCD TV Model #DP42647. The color suddenly started appearing with pinkish hues. Any bright spot takes on a pink color and has no distinct features. I have tried to manually...
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo . Obviously, that is more than the set sold for.
Oct 13, 2010 | Sanyo Televison & Video
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
The color on my tv is awful. sometines it can be bright blue sometimes orange then most times very dull in color
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
Nov 27, 2009 | Philips 50P8341 50" Rear Projection...
Sony KV-32v25 low brightness and little color
It's more than likely the tube, my friend. The chances of it being a power regulation problem is kind of remote at this stage of the game....accordianman
Oct 20, 2007 | Sony KV-32V25 32" TV
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
HP Compaq Presario v3000z Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
