Question about Panasonic Home Theater System System
Panasonic TV Instruction Manual
Hi, I have just bought a second-hand Panasonic CRT tv Model 32PB50 for use in student lodgings, complete with Sky box and VHS recorder. The (new) house has a standard co-ax socket as well as a communal aerial Sky outlet. Problem is there is no instruction manual and I don't understand why I am only getting the Sky introductory page. All I want for starters is the standard free-to-view channels, BBC1&2 , ITV, Ch4 etc. Don't really want to subscribe to Sky yet, although there is a viewing card with the Sky box.  Can anybody give me the Idiots Guide to setting up?
    Top Expert:
  • Panasonic Master
  • 26,176 Answers
Sky are satellite not TV aerial. You need a free-view box.
Posted on Apr 23, 2017
    Master:
  • Panasonic Master
  • 923 Answers
Is there anything mentioned about cable accessible via the remote ... assuming you have one that works for the unit?
leethedeuce
  • 4472 Answers
SOURCE: Setting up Panasonic SC-HT930 to Cable Box & TV
I am glad to assist you fully. I need the complete model of the TV and i will be able to tell you exactly how to hook it up. What connection/cable are you using from the cable box?
Thanks,
Lee
Posted on Jul 04, 2008
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
lynchms
  • 93 Answers
SOURCE: cant find tv codes
http://www.retrevo.com/search/v2/jsp/pdfViewer.jsp?doc=c45a91b6303859dd8437936788808ae6&page=1&sectid=1&q=Panasonic+SA-HT640
Posted on Feb 01, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: PANASONIC DVD HOME THEATRE SOUND SYSTEM SA-HT500
The SC-HT500 is only for use in the UK, Ireland, Australia, and a few other places - you will need at least a transformer if you want to try to use it in the US. The manual can be found here:
http://www.panasonic.com.au/support/downloads/more_info.cfm?objectID=842&fileTypeID=2&productCategoryID=47&productID=1526&listQueryString=fileTypeID%3D2%26productCategoryID%3D47%26productID%3D1526
-Tha Mp3 Doctor
Posted on Feb 21, 2009
SOURCE: Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
Posted on Nov 15, 2009
I HAVE BOUGHT A PANASONIC TXP50VT30 B BUT I FAIL TO CONNECT IT TO MY SKY HD BOX
You ahve to set up sky remote's code with Panasonig TV to receive sky programmes. Find out the codes and do the rest.
May 07, 2012 | Panasonic Televison & Video
Cant tune panasonic tx-32pb50
You must have its original remote control to select its auto-tune function.
I am running a Sky + HD box through my television Hitachi 26LD6600 using a HD lead. I have balanced the sky remote to the tv, but whenever we turn to Sky/digital tv we have to manually change the tv...
Hi, without a manual to hand, i don't know, but my Panasonic had the same problem, but I found somewhere in the settings, I could change it, it has something to do with AV and Digital TV and hdmi setup, give it a check.
I hope this helps to some degree, but give us a shout if you require more help.
Regards - Anthony
Feb 06, 2010 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Setting the channels
You can download the manual from the link below: http://safemanuals.com/download_94794.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Panasonic Home Theater System System Logo
57 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
