Question about Archos 605 Digital Media Player
Archos 605 stuck on demo mode tryed paper clip thing but same thing i tryed formatin but still dnt work usb not reconize on my pc is it doomed
  • rvf4 Oct 08, 2008
    I have my ARCHOS 605 on demo and cannot switch to regular mode. I tried with the reset button and turning on the DVR, but the reset button doesn´t work.
    I CAN connect the ARCHOS with my PC in Hard Disk Mode. Is there a way to switch to regular mode not involving the "reset button"
  • 4 Answers
Yes, there is, go to Menu, then i think it is System and towards the bottom there is demo or regular.
Posted on Dec 16, 2008
How to get out of the archos 605 demo mode wheh it keeps shutting off?
Demo software should not be on the device is sold to a customer. Because it is for stores to display them. If you have demo software working on your archos 5 press the power button and hold it for 10 seconds until it shuts off this will reset your device. And it should come up with normal user mode
Sep 04, 2009 | Archos Internet Media Tablet MP3 Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
I cant access my files when I plug my Archos 605 into a computer!
i had the same problem what i did was i downgraded my 605 to
Archos 605 Wifi (20GB-160GB) OS v 2.0.10
then i upgraded to Archos 605 Wifi (20GB-160GB) OS v 2.1.04
heres the link for 2.0.10 http://update.archos.com/5/a605/a605_r2.0.10/firmware_a605.aos
and heres the link for 2.1.04 http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
Jan 01, 2009 | Archos 605 WiFi Digital Media Player
Wont switch on
Same thing happened to me and I freaked out. Sit it on the charger overnight and then try to turn it on. Basically, what happened with mine was I had completely drained the battery to the point that, even though it was charging, it didn't have enough juice in the pack to turn itself on. If this doesn't work, then try resetting (use the end of a paper clip to push the "button" next to the area where the USB plugs in. If that doesn't work, try Archos tech support.
Dec 15, 2008 | Archos 605 WiFi Digital Media Player
ARCHOS 605 WIFI FIRMWARE DISABLED
hitesh_rao - the reset button is at the bottom by the USB and docking ports. Tiny hole, need a pin or paper clip. Once pressed, just switch it back on.
This may be a stupid question, but when trying to configure the TV IR controller function and entering the relevant codes for my TV's, it asks 'did the TV switch off = Yes/No?'
None of my TV's switch off and then I cannot go any further with the config. Is this right? I have logged this with Archos FOUR times now, and they just respond with 'the controller does not control your TV'. I am fully aware that it is not a TV controller, but then why does it want to switch off my TV during the config? I just want them to answer that question.
Somebody please help!
May 22, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi Multi media digital player
Seeing as this unit is so new, you have proberbly not got round to downloading anything important. ??
Try doing a system reset (the tiny hole on the base of the unit)
marked reset, gently insert a straightened paper clip,this should restore the factory settings.
Hope this helps
Apr 06, 2008 | Archos 605 WiFi Digital Media Player
PC no longer recognizes my Archos 605
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
Mar 24, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 is stuck in Demo mode
Should be the same as it was for my archos 604, try my instructions at
http://thepoetrydude2.blogspot.com
Dec 31, 2007 | Archos 605 Digital Media Player
Archos 605 in demo mode
We called tech support and you fix it by doing a reset on the base of the device. We used a paperclip to push the button. Hope this helps!
Oct 28, 2007 | Archos 605 Digital Media Player
Archos 605 Digital Media Player Logo
76 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
