Question about GE DSKP233EWWH Electric Portable Dryer
Dyrer belt will not tight up even from back side it way to loose
Spacemaker dryer i asked this last nite and got no answer what up with that men
  • 2 more comments
  • faceoff1 Oct 09, 2008
    spacemaker belt 8066064 cpt 7a25 ,26 440 5fsp made in usa this what on the belt it self ok it like it
    no matter how it put on around the drum the pulley wheel doesn't tight down why don't know
  • faceoff1 Oct 23, 2008
    hey now that i have the dry back on and it kind of tight now it not pulling the tub why what do i need to now and how many time do i push down light ok
    i have put the dryer blet back on and it kind of tight but it not trunning the dryer why but it spining
    around why is blet not turnning with the motor is the question about the dryer, not a flyer ok
  • faceoff1 Oct 24, 2008
    i well try this ok
This will show you the best routing Diagram
http://www.repair-help.com/kb/index.php?article=65
Posted on Oct 24, 2008
  • 750 Answers
You must elaborate and tell us more info.
Brand, Model year or age of fryer.
What you did and what was your problem????
We can not assist you without as much info as you can give us!
huuum
A waiting your post!
Posted on Oct 08, 2008
  • Neil Golan
    Neil Golan Oct 24, 2008
    It sounds like you did everything correct!
    Perhaps you would like to post a premium repair solution, and see if someone else has the answer.
Belt is loose
there are adjustment bolts on the back end of the treadmill. they are on either side. start with belt running about 3mph. tighten the side where the belt is closest. about 1/4 turn. give 15-20 seconds to see adjustment . when it is centered, tighten both bolts evenly until belt is tight.
Apr 19, 2014 | Nordic Track NordicTrack A2550 PRO...
Dryer won't turn
Okay, approach the dryer and first unplug it from power. Now very carefully take a flat blade screw driver and push the blade into the right or left front corners of the dryer box exterior between the mani box housing and the top. Carefully pry upward trying not to scar the porcelain paint finish. You will hear apop as the lid hold down spring detaches and releases. repeat on the other side. Place a hand on each of the lid corners and lift. the top will rise a angle upwards and to the back, use something to prop up the lid. Now looking down you will see the drum and a large narrow band running around the drums circumference . This is the drum belt if it is tight with no play. It is in
a proper position if it is about 4 to 6 inches from the back of the drum.
If it is displaced or hanging off the back see if it will move back up onto the drum. If when you do this it is loose or not tensioned tightly the belt will need adjusting down near the motor. To do this you must remove the back of the dryer, please be careful not break or disconnect the wires unless you mark them with tape to show where they were attached. Now this step works for both broken and displaced ,or improperly tensioned belts. at the motor near the bottom of the dryer you will see a pulleythat the belt attaches to on the motor right above the motor pulley you will see a tensioning bar or a pulley .this tensions the belt so it will tightly grip the drum of the dryer and the motor pulley.
Loosen the bracket position the belt and then retighten making sure the belt tension is tight on the drum. Now hand rotate the drum and see if the tension of the belt turns with the motor and does not slip.
IF it slips retension and recheck. If everything turns the way it should
Put the dryer back together, but do not entirely close the lid.Plug the dryer in, Set a dryer preset such as air dry and turn it on. if the
drum turns and doesn't squeal every thing is a okay . Turn it off and close the lid. Make sure the lid holddown catches lock the lid down.
Pop in a mid size load of clothes or Towels turn the unit on. If it squels it needs re tensioning. Now worst case scenario, the belt wont tension because it is stressed, frayed or stretched, go through the replacement procedure again. Proper Tension of the belt is key to peak operation. Good Luck if you are a stickler for proper belt deflection, a
technical term used forhow tight a belt can be before a belt is too tight, go to the dryer company's website and look for drum belt deflection measurements. I always used the belt rotation slip or no slip test. Have fun !!
Apr 05, 2014 | Maytag Dryers
Dyrer wont run lights come on but wont run
If the belt is not off, it may be a loose wire to the sensor that switches the dryer off when the belt is off or broken. Mine had that problem. If that doesn't work you will have to replace the tension pulley sensor.
Oct 27, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Power steering went out last nite and battery light came on serpoentine belt is loose
You'll need to replace the belt tensioner as it is probably weak and not keeping the correct tension on the belt.
Apr 02, 2011 | 2002 Ford Escort
Replaced belt tub turns but wont turn with load in it.Belt is 87/3/4-1/2 in length on model desf-l-2 dyrer
Sounds like you may need to adjust tension on the belt. To do that you have to expose the motor which will be in the back side of dryer and in the lower left or right hand side. Remove the access panel or on some models you have to remove entire back and then you will see the motor, there will probably be 2 bolts that need to be loosened on motor then you will need a small pry bar to apply tension on motor to tighten belt. Retighten bolts and put back cover on.
Feb 22, 2011 | Dryers
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Dyer no movement/heat on stack unit- washer fine
It sounds like the dryer motor please change thanks
rate me
Apr 20, 2009 | Dryers
Dyrer won't heat...
I can not find a diagram using your model number.
However, most Speed Quenn dryers have 2 screws on the bottom right and left sides of the front panel.
Unplug the dryer.
Remove the 2 screws.
Lift the panel forward and disconnect the door switch wires.
Reemove the belt and drum to access the heater circuit.
Jan 20, 2009 | Speed Queen AES28AWF Electric Dryer
Belt Not Tight
The belt gets tight when you press the pulley arm down place the belt over the outer edge of the pulley and then over the motor axis. The belt then runs like in a "eight". Christian
Jun 26, 2007 | GE DPSR483EA Electric Dryer
GE DSKP233EWWH Electric Portable Dryer Logo
66 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
