Question about Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer
Oasis washer repair
Sorry to bother. I saw that you had repair the Oasis washer yourself by replacing the board. I am thinking about doing that too. Is it difficult?
  • jolin10 Nov 21, 2008
    I am having the F1 error code before each wash cycle and rinse cycle.
    Thanks. Do you have detail instruction with pictures? Thanks.
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
Code F
These units have several very common error codes. the most common being error code F1. Oasis washer repair is simple. The link below has a video that explains how to replace the main control board on a Oasis washing machine.
Oasis Washing Machine Repair Video
http://www.appliancerepairlesson.com/
Mar 15, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
What does F1 error code mean on washer
It means you have a control board fault. Call Whirlpool and tell them the fault you are getting and see if it's recalled. There's a good chance. You can install yourself or have and appliance tech do it.
Rich
Western Appliance Repair Meridian
Nov 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The f1 code pops up
Hello
F1 error with your whirlpool cabrio is a common issue with these types of washers. This error indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known issue for them. Please get back to me if you have any other questions.
Kevin
Nov 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I saw the faq but I didn't see the answer. What does it mean when the Oasis keeps indicating F1 when a wash setting is chosen? If there is a charge to answer this question never mind.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Jun 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: I have KENMORE ELITE Oasis He and it kept repeated...
May 18, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 error on Kenmore Oasis HE Quietpak 9
question is not is it repairable but is it under warranty ..most likely bad control bd under console
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Oasis washer repair
The board is simple to replace, so you have an F1 error or you getting multiple F51 errors? I would like to offer the best so let me know. I have access to part nums for both issues, Thanks.
Oct 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE Top Loader washing machine
That would the user interface board (touch panel)behind the dash. Sorry, but not a cheap fix at all. Maybe search Ebay for the part, sometimes you can find it cheaper. Very expensive part and repair. Good Luck to you. Jim
Sep 07, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer Logo
50 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
