Question about RCA RCR311B Remote Control
Lost the manual for programing codes
I need the steps and codes to reprogram my remote. The batteries were taken out by mistake, and now it won't control the TV or DVD player. The TV is Panasonic, and the DVD player is Diamond Vision. Thanks Batteries were taken out of remote and memory was lost to tv. need directions on auto code search.
  • pat72540 Jan 06, 2009
    My remote was working fine when I programed my TV to shut off at night.
    The next night the remote wouldn't turn on my TV. The on and off button
    comes on red and blinks then goes out. The channel selector lights up
    green. I put new batteries in but it doesn't make a difference.
    Please help.
    Pat
  • Anonymous Jan 12, 2009
    i have the 3 way remote and i lost the paper to program my tv
I need to know if there is codes for a 5 disc changer dvd player that is Durabrand model
Posted on Oct 30, 2008
Central doorlock not working
in the event of a faulty/lost remote control or flat battery, the system can be overidden using two methods depending on the build date of the vehicle. up to september 1999 the ignition key overides the system after that date the digital key overide. The ignition key overide is in the form of a code of 5 digets recorded on a card and attached to owners manual. At the back. Code is also recorded on a tag with ignition key. If lost refer to dealer
Nov 28, 2012 | 2012 Hyundai Accent
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
I dropped my dvd remote and now it won't work
need to know the model of the DVD player and remote to be able to further assist you...but a quick google search with that model # and the phrases "program codes" and "how to" should quickly bring up a how to article or manual for the dvd player with reprogramming instructions.
Nov 04, 2012 | Toshiba Se-r0301 Q152 Remote Control
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
I have a universal remote and lost my manual, put new batteries in my remote...and now have to reprogram for my tv can you tell me the code for a sharp tv/vcr combination?
Here is a link to download the manual with instructions for programming the codes:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4220-manual.zip&area=other
Aug 18, 2011 | One For All URC4220 Remote Control
Need programing codes lost the manual
After some research I have attached a clickable PDF file for you to check out. It is a for a Sanyo Remote Control. Give these codes a try. If it is not for your exact remote control, my best guess is that SANYO remotes all share the same codes. It's worth a try.
Hope this helps!- CBR2009
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Apr 14, 2009 | Sanyo 6450160929 Remote Control
Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Nov 22, 2008 | Akai LCT3215/26 32 in. LCD Television
Reprogramming keyless entry remote...
Believe it or not, the information and instructions for reprogramming your particular model of vehicle is provided in your owner's manual. The dealer does not need to be involved unless you have lost all your programmed and programmable keys.
Aug 19, 2008 | 1999 Ford Econoline
Steps on how too program tv & vcr
here you go
when downloaded just extract the file, you'll then get a pdf file with full instruction and codes for remote
Jun 21, 2008 | One For All URC4220 Remote Control
i need to know how to program the remote
Dec 13, 2007 | RCA RCR311B Remote Control
RCA RCR311B Remote Control Logo
583 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
