Question about GE JBP71 Electric Kitchen Range
Clock and oven do not work right - lights flashing
The oven cleaning light is flashing, but is not in use.
I cannot set an oven temp.
The automatic oven light is on (green) and will not go off.
I disconnected the power for over an hour, and the problem is still there
The problem could be with the switch that is contrlled by the door lock handle. I disconected the power, raised the burner platform and removed the pannel just over the lock handle. With a hard toothbrush gently clean the contact of the switch.
Good luck
PS
It worked on mine.
Posted on Nov 13, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag oven problem
Somehow, usually when cleaning the face of the clock area, you locked the oven control. Go into your manual, and it will tell you how to unlock it. If I remember right, try holding in the broil button for 5 seconds, that might take it out of the lock mode.
Apr 04, 2008 | Kitchen Ranges
After a power outage, the oven control light keeps flashing.
You have too reset clock pressing two buttons works for me
Nov 09, 2015 | Ovens
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
Does not heat all the way, then clock and oven light start to flash
Unplug the unit and remove the back access panel for the control board. Check for any loose or burnt wires. If none are found, replace the control board. Here is a link to that part.
Electronic Control Board
Be sure to take note as to where the wires go!
Mar 03, 2014 | GE Spectra JBP78 Electric Kitchen Range
Wall oven on automatic with 0.00 flashing and will not go
You need to set the clock to the correct time and this should take it out of automatic mode, it should then work o.k
Nov 30, 2008 | Ovens
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Westinghouse self cleaning oven manual or owners manual
Many White-Westinghouse manuals can be found here: http://www.frigidaire.com/support/manuals.asp I had the same problem and was able to solve it. They didn't have the exact manual for mine (a KF450G), but they had one that was similar enough (KF580H) to solve this issue. Setting the knobs to clean is only part of the process, to get it to run you need to set the timer. Read the key information below transcribed from the manual: --- To set the controls for the cleaning cycle: 1) Close the oven door. 2) Be sure the clock shows the correct time of day. 3) Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will then pop out. 4) Push in and set the Stop Time knob for 2 to 3 hours past the Start Time. Example: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5) Turn the Temperature Control to CLEAN. 6) Turn the Selector to CLEAN. If all controls are set correctly, the oven signal light will come on and stay on until the oven reaches its cleaning temperature. It will then cycle on and off. --- There is more information in the manual, but it's much too much information to manually transcribe - I've only typed enough for you to get it working. Note that the LOCKED light won't light initially, it only lights once the oven exceeds 550 degrees. Once that light is on, the oven will not reopen until the temperature drops below that point, even if you stop the clean cycle. Be sure to empty out the storage drawer under the oven before cleaning.
Dec 08, 2007 | Kitchen Ranges
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Open Questions:
GE JBP71 Electric Kitchen Range Logo
150 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
