Question about Nova Development Art Explosion 40000 (AEM) for PC
ART EXPLOSION 40,000
Window xp says it cannot open the CD
3 Suggested Answers
  • 3 Answers
SOURCE: I cannot load my 40000 art explosion into my new Dell computer
ur computer might not meet the requirments if u want i can take alook at it i am a computer tech. u can email me at zvulich24@suddenlink.net
Posted on Apr 09, 2009
proton77
  • 1183 Answers
SOURCE: I have a new Dell
The Art explosion 40,000 is not compatible with windows xp.
It was build for windows 98. You would have to update the software package. The information about the same can be found at
http://www.novadevelopment.com/products/clipart.aspx
Thanks
proton
Is the "art explosion photo
I have this software and after changing to Windows Vista found that it was not supported
Jul 18, 2011 | Nova Development Computers & Internet
I cant install T-Shirt factory deluxe on mu computer windows 7
The following are your options for running this software:
1) Run your software in (XP) Compatibility mode - set in Program Properties-> Compatibility
2) Run in XP Mode if you have the appropriate version of Windows 7 (Professional and Ultimate) and Hardware (CPU must have Hardware Acceleration).
3) Install a Virtual Machine (such as the free Oracle VirtualBox) under Window 7 and then install an alternative Operating system (e.g. Windows XP) in this Virtual Machine and then the required software.
Hope it helps & Good luck!
Jun 12, 2011 | Nova Development Art Explosion T-Shirt...
I am running Windows XP, and have been using Nova's Art Explosion Publisher Pro 2.0. However, I recently had to reinstall operating system and all software and now I cannot get my system to read the first...
hi dontwakeme
Nova Development Art Explosion Publisher Pro 2.0 only running on windows 98/2000/me and XP
what is your system operation you use now?
if vista or 7, you need higher version of Nova Development Art Explosion Publisher Pro
Mar 20, 2011 | Nova Development Art Explosion Publisher...
I recently upgraded to Windows 7. I went to install this software again but says that it is not compatable with the drivers. How to install this?
Windows 7 has a "Program Compatibility Wizard".
Launch this Wizard, and tell Windows that you want to install a Windows XP application.
Point to the CD-ROM containing the software, and install it.
Dec 17, 2010 | Nova Development Art Explosion Scrapbook...
Create and share toolbar is grayed out
try this
The toolbars can be turned off. They can also be dragged out of the viewable area. If they are turned off, they can be turned on by going to the View menu, to the Toolbars sub-menu and selecting the toolbar that is missing. If it already has a check next to it and it is missing from the program, then it has been dragged out of the viewable area. To correct that:
Warning: Make sure that you are only deleting folder/keys that you are directed to delete in the Registry. Deleting any other folder/keys may cause problems with your system or other programs. Novadevelopment assumes no liability for changes you make in the Registry.
  1. Close the Publisher Pro program.
  2. Go to the Start button and select the Run option.
  3. On the Run window, type “regedit” without the quotes in the Open field.
  4. Click the ON button. This will open your Registry Editor program.
  5. Scroll to the top of the left-hand side of the window to where you can see the My Computer option.
  6. Click the plus sign (+) next to the HKEY_CURRENT_USER folder and this will expand a list below it. If it has a minus sign (-) next to it, skip to the next step.
  7. Click the plus sign (+) next to the Software folder and this will expand a list below it. If it has a minus sign (-) next to it, skip to the next step.
  8. On the list that appears below Software, locate the folder labeled Nova Development. Click the plus sign (+) next to the Nova Development folder. If it has a minus sign (-) next to it, skip to the next step.
  9. On the list that appears below the Nova Development folder, locate the folder labeled Art Explosion Publisher Pro. Click the label for the folder Art Explosion Publisher Pro. It should now be highlighted.
  10. On the Art Explosion Publisher Pro folder name is highlighted, go to the Edit menu and select the Delete option. On the warning box that confirms the delete, select the Yes button.
  11. Close the Registry Editor window.
Jun 06, 2010 | Nova Development Photo Explosion Deluxe...
I cant get the art explosion 750,000 to download to my Macintosh
To download or to install? Because most Mac installs usually just mean dragging an application from the image file mounted on the desktop to the Applications folder.
Mar 18, 2010 | Nova Development Art Explosion 750000...
I have a new Dell computer with Microsoft XP, but I cannot load my Art Explosion 40,000 images. Is it possible to load this to XP?
Thanks
proton
Apr 09, 2009 | Nova Development Art Explosion 40000 (AEM)...
Loading Art Explosion 2.0 publisher pro on windows vista
I had to download an upgrade from their website to allow Vista to operate properly.
Mar 07, 2009 | Novatel Art Explosion Publisher Pro 2.0...
Problem installing,deluxe version 7,greeting card
insert disk
click on MYCOMPUTER and then RIGHT-CLICK on the drive and then click or EXPLORE
This should open a folder for the disk. somewhere in there should be an EXE file with SETUP in the title.
if the folder doesn't display the contents you may have a bad disk
if it does and you cant find a setup program let me know.
is this the only disk you have had trouble with lately?
Dec 26, 2008 | Nova Development Art Explosion Greeting...
Nova Development Art Explosion 40000 (AEM) for PC Logo
62 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
