Question about Kenmore Refrigerators
Kenmore refrigerator the refrigerator keeps turning off and after 2-3 hours and turning the knob over and over again then it starts up again
  • 943 Answers
HI thanks for the question the problem is with the thermostat . the knob you keep turning.thats the part that turns off fridge when cold enough . i would replace the thermostat the appliance doc. please rate my answer .thanks
Posted on Oct 08, 2008
Bocsh 1400 express f21 keeps flashing
This Bosch looks like a Kenmore HE2, and may be made by the same manufacturer.
In the Kenmore HE2 manual it states:
"F" Variables [F4 to F16] (Electrical problem)
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call for service.
If it's not working still, try asking advice at . They have helped me in the past, and they have parts too.
May 29, 2014 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
My refrigerator only kicks on when I adjust the temp knob.
You need to replace ( or have it replaced ) , the thermostat . The piece the knob pushes onto . The liquid is seperated inside the thermostat cap tube , causing the internal contact not to close . Also , a tap on the knob , will start the refrig , until it reaches temp , but then may not restart until another tap . Replace it and that will solve the problem .
Apr 20, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
The refrigerator keeps going into defrost mode and staying there. Moving the thermostat to off and back on again resets it and the compressor restarts.
You need to replace the thermostat . When the thermostat temperature is reached , it will cycle the compressor off . When time to come back on , it will not start . Instead of turning the thermostat off , try tapping on the thermostat knob . If the unit starts , this will confirm that the thermostat needs replaced .
Oct 15, 2009 | Kenmore 53092 / 53094 Side by Side...
Kenmore side by side not starting after defrost.
Probably has a defective defrost control from what you are describing.
Dec 17, 2008 | Whirlpool 21.8 cu. ft. Side-By-Side...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Kenmore 106.7687461 about once a week refrig stop, light still on?
Try to locate the defrost timer. It sounds like the defrost timer has an intermittent fault and is not operating as it should. It should be situated in the compressor compartment. It is a white or black box with a little knob protruding from it. When the motor stops again, try turning the little knob on the timer untill you hear a loud click. The motor should then start running again. If it does, the timer is faulty. Replace it.
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
