Question about Car Audio & Video
Best way to set up my car sound system???
Ok so ive jus bought from my best friends girlfriend a full set up for the back of my escort 1.6 zetec(i was given it before you ask). lol
Ive got 2 x JL audio 12" 12W0 subs, a Pheonix Gold Octane R.5.0.1 amp and a Phoenix Gold R.5.0.4 and a power cap just to make sure theres plenty of power... up front ive got a sony xplod head unit from my old car 4 x 50 w.
Now im on standard companants which arent actually too bad. my main question is what is going to be the most effective way to set it up?
i listen to hard dance music so im lookin for it to be quite punchy...
do i run one sub off each amp or both off one? can u link the two amps too increase the output then put the subs in line with each other? is there a certain frequency i need to use? do i use the 2 ohm or 4 ohm setting? etc
ive heard these subs and amps run in friends cars and they sounded flippin awesome yet mine sounds like a cheap set up.... which we can all see from the spec it aint! all your help would be much appreciated.
thanks
brett
  • 1 more comment
  • nibbzy Oct 09, 2008
    Its a sealed box with a baffle board inbetween the two subs, ill measure it later to get exact dimensions. what about the other amp? surely if i run both subs off one amp im gonna get less bass than if i ran them both one off each?
    thanks for all your help ill try and get more details later.
    It was a purpose built box aswell it was bought ready made carpeted and sealed i would say its about 12" deep on the top and say 15" at the bottom and i would say aprox 35" long. Flat front with two sub holes in it and sloped back to match the shape of the chair. then its got the connectors on each end.
    The amp does not have an option for off on the subsonic filter it has a range from 25 up to 50. so not too sure what to do there? and also the frequency setting has 30hz then nothing all the way round too 300hz so i can only guess where 65 - 80 is?
    here is ma set up sorry its not too good a pic but its best i can do with me phone!
    Scholar:
  • 92 Answers
This is a multi-tiered question. First of all, you're going to want to run the subs at a 2ohm load (if the amp is capable) to get the maximum power from it. Use the 5.0.1 for the subs only, that's what it's designed for. Run the cap in conjunction with only the sub amp as it has the largest power requirement. You can not link the two amps to increase output as they are first of all different amps and second of all not designed to run that way. Some amps are but they must be identical.
Set the crossover on the sub amp probably no higher than 80Hz (I like it lower than that but that's a personal preference) and turn the sub-sonic filter off.
Now, one of the most important things about a subwoofer is it's encosure. If it's a properly built box designed for your subs specifically then you should be ok. You dont' specify if it's ported or sealed etc. That would be helpful to know as well as it's approximate size (air volume).
The head unit can also have some bearing on how things sound, as I recall the Sony X-Plod units are fairly decent for the price and if set up properly should sound ok.
If you need further assistance please provide a little more info about the sub enclosure etc.
good luck!
Posted on Oct 08, 2008
  • Inno Laur Oct 08, 2008
    Oh, and facing the subwoofers toward the back of the car will make improvements to the amount of bass you get as well.
What does it mean when an escort advertises as GFE? What does that entail?
The Girlfriend Experience is exactly as it sounds; the time that you'd spend with an escort would be like the time time you'd spend with a girlfriend. You could do things like going out on dinner dates, going out for long walks, or even just playing around in bed before you start making out with her. Here are the full specks on the GFE service
Feb 25, 2017 | Cars & Trucks
Timing marks on 96 ford escort zetec
remove the rocker cover and the timing marks are on the back of the cams ,on the end are two slots one on each cam ,use a flat piece of metal to lock into place with teh valves on NO1 cyl pointing upwards and outwards and no1 cylinder at the TDC find this by using a screwdriver down the plug hole ,right er indoors waiting to go to market if in any doubt please post a reply and i will answer it later today.best of british with it
Nov 13, 2011 | 1996 Ford Escort 4 Door
Set timing marks for escort zetec 16 v
valve timing marks on back of cams ,a slot on back of cam has to level with the head ,crank timing on the flywheel ,hole in bellhousing
Jun 10, 2010 | 1996 Ford Escort 4 Door
How to set timing marks on 1.8 16v Zetec Escort 97
how I change the fusebox of Escort Zetec 1.8 (1998) SW?
Jun 07, 2010 | 1997 Ford Escort
Replace timing belt on 2001 ford escort
Zetec Timing part 1
Zetec Timing part 2
Your first born and 6 gold bars should be enough thanks.
May 19, 2010 | 2001 Ford Escort ZX2
Spark plug setting 1998 escort 1.8 zetec
The Spark Plug Gap .054 (In thousandths of an inch)
Caution! Gap is not adjustable on certain plug brands
Aug 08, 2009 | 1998 Ford Escort
1998 Ford Escort 1.6 Zetec Starter motor
need to know how to fit a starter motor for a s reg escort
Jun 26, 2009 | 1998 Ford Escort
1995 escort what are the timing marks for timing belt
how to set timing mark ford ecort zetec 1.8
Aug 27, 2008 | 1991 Ford Escort
Ford escort
Replace the Spark Plug wires, they burn through and short to the valve cover/cylinder head causing a miss under load, very common concern with this Mazda engine that was used in your Escort GT. Buy the best wire set you can find, or the problem will re-occur very quickly. Auto-lite makes a good set at a good price, avail at most chain parts stores like Kragen, Auto Zone etc.
Jun 06, 2008 | 1995 Ford Escort
Car Audio & Video Logo
747 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
