Question about Fisher DD603FCSS Dishwasher
F1 alarm keep coming back on both drawer
F1 alarm keep coming back on although I,ve tried to dry the sensor at the bottom of the lower draw
I just had the same issue as a result of "mother-in-law" using regular liquid dish detergent in both drawers. After numberous attempts of cleaning out each drawer it still was beeping and attempting to drain both drawers even when the water was drained it continue to run and beep.
My presumption of what occurred is the wrong soup caused so much suds that it triggered the flood sensor. I removed both drawers and discovered water in the base area and moisture throughout. After disconnecting the power to the unit I removed the white plastic cover and exposed the small circuit board. I disconnected the power leads and the screw holding the board in place and lifted it up a bit. I then used a hair dryer for about 15 minutes until the entire area was dry and put it back together and has worked just fine. You will see a service diagram taped to the back pannel when you remove the bottom drawer. It has additional information on various error codes and the instructions on how to trouble shoot problems. I would also remind you to run water in the units if the cause was due to the wrong type of soap as the residue will continue to recreate the same problem.
I hope this helps.
Mark
Posted on Feb 01, 2009
  • 126 Answers
SOURCE: my dish washer has a f1 code i put to much
f1 code indicates a leak.open bottom drawer,find the spring clips on side of tub where tub meets the front panel.push the clip and you will be able to slide the track back and remove tub. put tub on floor to left you should see a puddle,dry it up should be ok. Sensor is sensitive to moisture allow 24 hrs to reset if all visible water has been dried up. hope this helps ,please rate my solution :)
Posted on Jun 25, 2009
  • 92 Answers
SOURCE: f1
i can almost garentee you have a broken harness in the back of the machine and the piece of plastic is getting caught between the lid and tub. pull out the drawer there are two tabs in the bottom front corners push in and pull the drawer out futher you can now see behind the tub check the lid gasket is there a dimple if so you may be able to reform w/ you finger and some heat(hairdryer). there is an updated braket for your hoses that come w/ instructions. only other thing is the lid acuators which have also been updated.
Posted on Jan 20, 2008
SOURCE: dishwasher f1 problem
thanks for the follow up. I ended up calling a service representative in my area to complete the repair.
Posted on Aug 18, 2008
mark_37388
  • 100 Answers
SOURCE: Fisher & Paykel dishwasher:
The F1 code mean that there is water in the bottom of the cabinet one of your drawers are leaking
Posted on Mar 27, 2009
  • 81 Answers
SOURCE: Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Posted on Sep 24, 2009
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
Jan 24, 2013 | Fisher DD603FCSS Dishwasher
3 problems: 1. lower drawer is hard to close; seems to be sticking on something. 2. lower drawer retains water (2 inches) after completing a cycle. 3. F1 fault code on both drawers with alert...
ok where to start, first thing the bottom draw is hard to close because they use 2 little motors on either side to pull a lid with a seal on it down on top of each draw when u start it to keep the water in, if its hard to close the motors are damaged and arnt lifting the lid back up when the cycle finishes making it hard to open and shut, now the F1 fault means the filter circuit board in the base of the machine has been activated basically a flood sensor (and controls minor components ie lid actuators), the unit should beep and flash and go spaztic and you should hear the drain pump come on continuously til u turn it off at the wall thats its way of trying to stop a leak by removing any water it can but will not actually remove the water from the base where the switch is, you will probably find it will work now as the water will have dried and stopped triggering the switch but wont stay like that for long, that machine has major issues its leaking bad from somewhere and id say it leaked onto the lid motors and fried em, the parts you will most probably have to replace is the filter board in the base, both bottom draw lid actuators (small motors), probably the bottom draw lid if you damaged the seal pulling the draw in and out and whatever is leaking and if any other componets where damaged by water, so if its outta warranty id go buy a new 1 with 5 year extended warranty
Oct 26, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishwasher showing wrench symbol after using dishwashing liquid
I am assuming this F1 error is coming in only one drawer and that you are able to run the second drawer as normal.
In the case of your dishwasher the F1 error occured because the foam would have overflowed over the drawer top into the base of the unit. This would have triggered a flood switch which is there to protect water damage to the dishwasher. You can either wait a few more days until the base of the dishwasher drawer unit dries up or you can dry it yourself.
To dry the base, extend the drawer as far out as possible (turn mains power off first). The use a few towels and push them on to the base. Pull the towels out and dry the base especially the centre of it with a hair dryer.
The F1 should disappear once you put power back on .
Hope this helps. You have a very helful child who sets the dishwasher up. I have to keep pushing my children to even empty it.
Jun 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault
Hi . F1 means your machine has triggered the flood alarm. either you have a leak on one of your drawers or water or soap suds has escaped throe the overflow. now the 1st thing to do is turn your machine off at the wall. then leave it for a couple of days to let it dry out. then turn it on and try the lower drawer throe a cycle,if it doesn't go to F1 then try the top drawer. if it doesn't go to F1 then it might be fixed.if it does go to F1 on any drawer then please reply and tell me which drawer it is and i can help you further.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Default code F1
if you physically forced door open then started f1, its possible that there is no issue and you can reset it. F1 is a code for water leak... if you can remove the lower drawer from the cabinet, youll find water in the lower tray, youll need to dry up this water in order to have the f1 code stop
Nov 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher problem
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel No power to bottow drawer
the board you checked has the sensor have you removed and dried off both of them? and check the actuator motors that hold the lid down these fail causing the F! due to the lid not sealing tight'
May 08, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error on the 1 draw dishwasher
I've never found personal ranting to work myself. However F1 is meant to be a flood warning, there's a sensor in the bottom of the drawer unit that stops the dishwasher if water accumulates in the casing, not the drawers!
So the error could be caused by a leaky hose, a broken or fouled lid or a blocked drain hose stopping the drawer from pumping out, at least these are the problems I've heard of or had.
TURN THE POWER OFF BEFORE TRYING THE FOLLOWING.
To see if you have water in the unit you need to remove the lower drawer, to do this open the lower drawer and you'll find the drawer release clips on each side of the drawer in the corner to the front and at the bottom. When doing this always support the front of the drawer in one hand while releasing the clips with the other. To release the clip push it in and slide it back 3-4cm while gently lifting the front of the drawer (don't try to lift it out, you only want to make the clip slide back easier!). Repeat this with each clip.
The drawer is on telescopic side rails, so while supporting the front you need to slide each side back, the clips you released are at the end of each rail and you can slide these easily by feeling just under the edge of the drawer. When they're both slid to the back you should find that the drawer will slide further forward and you can lift it out but don't try and pull it right out because all the hoses and wires are connected, just have a towel or something that you can put on the floor to protect the drawer and leave it there.
You should now be able to see into the base of the unit and see if there's water there. The sensor is attached to the bottom panel in the casing, if there's water puddled here you may have a hose or lid leak, you'll need to dry the casing out (thorougly, probably with a hair dryer before you can clear the F1 error).
On older models the lid motors on either side of the unit (they were white) did have a reputation for breaking, if you see water splashed around the sides it might be one of these that's gone, check for tell-tale signs for leaky hoses too (that would be water where it's not meant to be).
To replace motors and hoses is up to you.
Jan 11, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code on Fisher and Paykel dishdrawer
Just had the same problem, removed the excess water from the drawers, turned off the power, removed the bottom drawer by pushing in the lugs at the bottom of the drawer where it butts up to the drawer front and pulling out the drawer. Then had to mop up with 4 t-towels and half a roll of kitchen roll the water in the bottom of the machine housing. The water gets into the electronics at the rear of the housing and obviously warns you of this by the F1 code?. I removed the white cover over the electronics with a screwdriver by pushing it into a slot then sliding the cover across to the right, it is indicated on the cover how to remove it. I also then removed the screw on top of the PCB (printed circuit board) and lifted up the grey plastic base and wiped under that and the under side of the PCB. The PCB unclips on the left hand end of it and lifts out, try not to pull the cables out though. I then used a hair dryer as suggested by someone else on here to dry out any excess that you could not wipe dry, my daughters Hello Kitty hair dryer didn't last long though, she's not impressed! So try not to stick the dryer right in the housing to avoid overheating it. About 5 minutes did the trick for me, then re-assembled everything, turned it on and hey presto! It worked!!!! Its not that hard, good luck!!!
Jun 06, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher DD603FCSS Dishwasher Logo
130 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
