Canon IR2000 error 100
Whats a system error e100 and how do I clear it. It happenned after changing the toner cartridge. I've turned off all power and restarted several times to no avail.
  • 1,326 Answers
A E100 is the laser shutter is not opening. There is a spring that most likely came off. It is actuated by the door closing. You may have to get a service rep. to repair it for you..
Posted on Oct 10, 2008
System error e100
m/c on go additional key then printer then printer reset then yes then power cycle hope problem was solved
Jan 25, 2014 | Canon imageCLASS Office Equipment &...
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
I just changed the Toner cartridge and got an E100
A E100 is a Laser code... Look to make sure that the toner lever is in the correct potistion and that the front door is closed all the way and correctly.
Jul 23, 2009 | Office Equipment & Supplies
System Error E100
Most likely, the tab on the rear side of drum unit has broken off. Thus causing the Lazer Shutter not to open. There are 3 or 4 other possibilities other than replacing the drum unit.
Jun 02, 2009 | Canon iR 2020i Laser Printer
Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
System error E000 in conon ir2000
Sir,
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Thanks
Good Luck
Apr 28, 2009 | Canon imageRUNNER 2000 Copier
Error code
Under service mode ( MENU and # ) find clear, select err, and OK. Turn off and on.
If after that you still have this message, you need to find the problem in fixing assy. Its probably bad thermistor or heating lamp.
Call service.
Nov 26, 2008 | Canon PIXMA iP1600 Printer
Systems Error E100
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Oct 02, 2008 | Canon Image Runner 1630 Copier Copier
719 people viewed this question
k24674
jasbo
jasbo
