Question about Maytag Atlantis MDG7400AW Gas Dryer
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
WE CLEANED OUT VENTS AND MADE SURE NO LINT IN TRAP.
TOOK OFF FRONT OF DRYER AND HEATING COIL LIGHTS AND FLAME COMES ON RUNS FOR ABOUT FIVE MINUTES AND THEN GOES OUT. VACCUMED OUT BOTTOM OF DYER AND STILL SAME PROBLEM? SOMEONE SUGGESTED IT WAS THE HIGH LIMIT SWITCH, ANY SUGGESTIONS?????
PLEASE HELP
  • Anonymous Oct 27, 2008
    I am experiancing the same problem. The dryer runs but no heat. I cleaned out the vents also. How did you get the front of the dryer off? I need to clean lint out in the actual blower turbine. Thanks.
  • 164 Answers
The flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Posted on Nov 04, 2008
No heat at all with this dryer! the gas is on. do I need to light it in some way?
Posted on Feb 22, 2010
Maytag atlantis gas dryer not heating up
I thank you need a new Heating Element Assembly part # Y308612 here is a image of the Heating Element Assembly
Jan 20, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
How do i clean the lint trap in side the dryer. I can't figure out how to take it apart.
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it, or if the vent itself has finger holes or something that you can grab and pull or slide it open.
In some front loading models the two vents are at the back and both look like nonremovable vents. If that's the case, one actually pulls right out easily. It might then have two parts (the grate on the dryer side and the screen on the exhaust side) that snap or slide apart, with a space between for collecting lint. If that's the case, and you haven't cleared it in a long time, it will be packed full of lint. The two parts snap or slide apart, then you can get at the lint and remove it. Then snap or slide it back together and just push it back securely in place in the dryer.
Jun 13, 2010 | Maytag Atlantis MDE7657BY Electric Dryer
Lint problem
Yes, check filter assembly is not blocked.
Mar 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer works only on high heat; will not respond to touch pad.
Replace the gas valve coils. They have gotten weak and do not open on the next call for heat.
Aug 30, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Maytag Atlantis MDG7400AW Gas Dryer Logo
765 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
