Question about Dryers
How do you change the thermostat on the G85C TUMBLE DRYER
  • 1 more comment
  • elliottverna Oct 08, 2008
    Its an Indesit
    How do I replace the thermostat on an Indesit G85C Tumble Dryer
    Thanks but I need to replace the thermo myself so I need info as where it is and how to replace it.
    Top Expert:
  • Dryers Master
  • 78,289 Answers
GENERAL INSTRUCTION FOR REPLACING A DRYER THERMSTAT
Disconnect the power source to your dryer before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel. Your dryer uses multiple thermostats to regulate its internal temperature. The cycle selected determines which thermostat is used. The cycling thermostat can be found somewhere in the path of air that is leaving the drum. So, it could be found on the blower wheel housing or inside the venting/exhaust system. Dryer thermostats are usually oval shaped and about an inch and a half in length. Also, there should be two wires leading to each thermostat. Label these wires before you remove them so that you are able to correctly reconnect them later.
The wires to the thermostat are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you.
The thermostat itself is attached to the dryer with two screws. Remove both screws and discard faulty cycling thermostat. Install new thermostat, securing it in place with two screws. Reconnect the two wires, reassemble your clothes dryer, and restore power to the unit. Run your dryer through a cycle to make sure it is working properly
Posted on Oct 08, 2008
  • 749 Answers
This thermostat should only be fitted by a qualified technician...it consists of a one shot cut-out and an autoreset cut-out. Both must be fitted because if the one shot has operated, the auto resetwill also have been blown, or be faulty, as it works at a lower temperature
    Guru:
  • 558 Answers
You can get the manual for installation and use using this link:
G85C Tumble Dryer
Free download, Just provide your name, email and postal Code
For Thermostat you can contact to Partmaster.co.uk 0844-800-3456, they will provide you service and installation minimal cost.
Regards
Ellin
    President:
  • 2,712 Answers
What is the make pls?
Hotpoint TCL 780G condensor tumble dryer
hi make sure heater element is not touching back of dryer causing a short or break on wire catching casing
Mar 05, 2014 | Hotpoint Dryers
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
video section
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
Tip
on May 10, 2010 | SNK Knight 43AW Electric Dryer
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Apr 19, 2010 | Dryers
White knight tumble dryer not drying clothes. element is still hot. what is the problem?
Mar 23, 2010 | Whirlpool Dryers
Candy Nova CDC 266 tumble dryer. The tumble dryer tumbles but I have no heat and the filter light stays on constantly. Any ideas of what it could be?
hi ya this is the thermostat at the back of machine external,take the fan housing of it is nomaly the top one .beware change like for like do not exceed the temp rating of the stat.
hope you solve it
andy bird www.shropdive.co.uk
May 05, 2008 | Dryers
Dryers Logo
108 people viewed this question
Top Dryers Experts
