Cassette is stuck in the my stereo
My cassette is stuck inside my stereo dont want to force it out , thanking you in advance for your time and trouble mike
  • 2 more comments
  • mikewilson4 Oct 14, 2008
    J,V,C MODEL # CAFSG3 thanking u in advance for your time and trouble ,,,,,,, mike
  • mikewilson4 Oct 16, 2008
    its electrical solenoid. touch the door and it opens , now the tape dont play and i cant get it out it stuck in there door wont open ,,,,,,,,,,,,,,,,,,, mike
  • hellsmaw84 May 11, 2010
    is it mechanical open or electrical solenoid open?
    what kind of stereo is it?
  • 4 Answers
It sounds like a mechanical push open/close, but if it is solenoid then you will have to open it up and find out what has it jammed. my best advice is to take it to a service center and have it worked on.
Posted on Oct 17, 2008
VHS cassettes stuck NOT in a VCR. I have a few old VHS cassettes that I want to copy to DVDs. The problem is that that the tape in these cassettes gets stuck. Not only in the VCR. When I use an external...
Yes,Loosen all the VHS cassette screws from the video cassette plastic cover.Take ur finger shaking and rewine wheel a few times with it with ur finger.The VHS tapes shoud work find now.
Dec 06, 2010 | Televison & Video
Tape deck is stuck
push the eject button at the same time get a nail file and insert it in the tape slot
on the right hand side of the deck
it may take three hands one to push eject one to push the eject mechanism inside the radio behind the tape
and one to help remove the tape
if that doesnt work....dont try forcing anything as the stereo WILL break..... take the stereo out of the car, so it is not connected to the electrics, then either, gently take it apart with a screwdriver
I would suspect the belts, look for any small motors and missing belts. You may be able to manualy turn a wheel or gear till it ejects.
if your not comfortable doing this urself with the above said porcedures... its better to take it to the dealer...
regards iversh
A very helpful rating is appreciated for answering Your Query
Aug 30, 2009 | Panasonic RX-ED707 Boombox
Jammed cassette tape in car stereo
your cassette seems to be jammed, try removing the player open it which should reveal the trapped cassette then try to carefully remove the tape as it may have got stuck around the capstans(rubber bits) sometimes when tapes haveen't been played for a long time they tend to become loose, try to ensure that the tape is tight by using a pencil inserted into the spool and turn it until the tape tightens please take care not to over tighten. good luk
Apr 28, 2009 | Car Audio & Video
Tape will not turn
The more detailed the description of the problem, the better for diagnosing the root cause. Thanks.
It sounds like you have a couple of problems. I'll address them as you have them numbered above.
1. Decks typically have belts to drive the various 'reel' mechanisms. Therefore, they can slip without breaking anything inside the machine or the tape. Your first symptom leads me in that direction.
2. That it migrated is mysterious, unless Sony is using a common motor to handle both decks' reel duties.
3. This symptom may have something to do with the root cause of both sides jamming...
Do the cassette well doors come off, say, for cleaning? Could they be dislodge? If so, they may have something to do with the jamming problems in # 1 and #2 as the doors play a part in positioning the cassette and holding it in place against the reel motor cogs. How do the doors operate with NO tape inserted?
Does it take excessive force to close the door only WITH a tape? make sure the tape is fully seated before closing the door. The capstans (directly below each reel cog) have to engage through the small holes at the lower edge of the cassette. They should be straight and clean. Any dirt or oxide on them will cause problems as these are what move the tape at the precise speed necessary for good playback or recording.
My hipshot recommendation, otherwise, is to look around inside the cassette wells very carefully for any foreign matter, debris, dust bunnies.
Do you maintain the deck as recommended?
Apr 02, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Brother Intellifax 4100
1-pull the paper cassette out-fan the paper and adjust the cassette to the proper size of the paper.2-after you remove the cassette from the machine have a look in cassette bay with help of any light source and cofirm there is no foreign object stuck inside(pieces of paper-pins etc-after that if the problem exist apply a spray from contact cleanr with it is tube inside the bay of cassette in direction of machine rear frame.and insert the cassetee firmly many times to activate cassette switches.
Mar 03, 2008 | Brother IntelliFAX 4100 Laser Fax
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
Stuck tape
If you haven't already done so, don't get overly forceful to avoid bending or breaking something. Often the cassette carriage mechanism is gear driven, and by moving the gear one direction or the other will unload the tape. You may need to disassemble the machine further to gain access to the drive mechanisim. Sometimes the carriage mech. can be entirely removed from the VCR by removing the attachment screws. Other times, these screws are made inaccessible by the tape itself. Look down on the right side of the carriage. If you do remove the carriage, mark the gear positioning first! as the gears must be positioned back exactly as they were from the manufacturer. You might need to employ the services of a technician if things are complicated.
May 26, 2007 | Panasonic AG-DV2000 Mini DV VCR
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
184 people viewed this question
 Grubhead
Grubhead
