Question about Jenn-Air Ovens
Jenn Air Oven Repair
I have a Jenn-Air Oven Model W122. Recently the analog timer/clock on the control panel has been making a grinding noise. I have looked on-line for a replacement but all the sourcews I checked indicate that this item has been dicontinued. Can you supply me this part or recommend where I can buy a replacement or get this repaired. It appears all the functions of the oven (broiler/convection/bake) are plugged into the back of this console. It would be a shame to have to replace the whole oven for the sake of a timer/clock. Any assistance would be greatly appreciated. Thanks.
  • 943 Answers
HI thanks for the question. you can by pass the clock so the oven will work without the timer. call a tech near you, and ask them to by pass the timer. if i could get the wiring diagram, i could tell you how . its a simple thing to do. thanks the appliance doc. please rate my answer.thanks
Posted on Oct 08, 2008
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-air SVD48600P oven will not work / F3 error . I recently replace the expense control / clock unit on my oven because it would not heat. This was advice from repair person. Once replaced the over...
Hi jmhostetler9,
This F3 that keeps flashing on your oven is caused by a shorted or open oven temperature sensor (RTD). To fix this problem check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model # ready when you call.
Hope this helps.
Dec 22, 2009 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air expressions wall oven clock went dim, now out completely
This may be no help at all but;
Similar ovens have had problems with timer components going bad (overheating) and causing this problem.
First contact Jen- air customer service about a recall or replacement timer board, if that doesn't work remove the timer board and look for a discolored or leaking capacitor, These capacitors are less than a buck as opposed to over a hundred for a replacement board. If you don't want to solder it yourself find your friendly local geek from the radio or electronics club or get a recomendation from the local electronics parts house,
Nov 08, 2009 | Ovens
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Some selections on the touch pad on my Jenn-air oven aren't working
Hi, There is a way to replace the keypad. Sometimes you need to replace the clock assembly. I could let you know for sure if I had the Model #
May 08, 2009 | Ovens
Clock readability
The problem is very likely a bad capacitor on the clock module. See this link for more info:
May 03, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
237 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
